mid 70's Dodge 3/4 ton Dana 44 axle swap?
Discussion in 'The Garage' started by richheezee, Nov 30, 2005.
  1. richheezee
    richheezee 1/2 ton status
    Dec 29, 2003
    116
    San Jose CA
    i searched and pulled up vague explanations on installing an 8 lug dodge dana 44 front axle into a fullsize blazer. i have a lead on an 8 lug dodge dana 44 front axle with the gearing to match my rear 14 bolt and i just wanted to know if it would be worth the trouble to get it to work in my truck or to wait it out longer for a GM 8 lug dana 44 or 8 lug 10 bolt. i only do light wheeling running only 35" tires and cannot afford a 60 at this time. so, a dana 60 is out of the question unless i find one for the same price as this dodge dana 44 i am looking at. LMAO! :haha: i know it's possible, but what needs to be done and modded exactly? :confused:
  2. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    I have experience w/ the Dodge D44. I used 1980 Dodge 3/4T axles for the build of my FunBuggy.
    The wierd thing about the Dodge is that the axles are a full 2" narrower than the Chevy. This may not bother you, but it will get your goat when you figg'r out how hard it can be to get a replacement for the "short side" inner axle. The long side is not exactly the same length as the Chevy, but it is close enough that it will interchange.
    If none of this bothers you... then use it!...
    Marv
  3. sweetk30
    Nov 1, 2004
    25,539
    539
    horseheads , ny 14845
    look out some were full time with unitized bearings. tell by the big nut in the hub area and no hub at all.
  4. richheezee
    Dec 29, 2003
    116
    San Jose CA
    sweet fun buggy. :bow: yah, i don't think the width would bother me.
    the axle i'm looking at is full time but i figure i can swap in GM spindles and locking hubs. are dodge knuckles 6 bolt? if not can i swap to GM knuckles? or am i thinking crazy?
  5. bigjbear
    Feb 18, 2000
    13,970
    451
    Marietta GA
    The stub shafts on my 3/4 ton Dodge (M880) were flanged with no provisions for locking hubs. So you would need new stubshafts, bearing hubs, and locking hubs to convert. Don't forget to budget for this as well. Also, don't get excited when you see 3 u-bolts/2 studs, Dodge did that w/ the D44s too.
  6. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    How much did You pay for the Dodge axel? I have a GM Dana 60 thats for sale with the price going down every day!
  7. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    can you not find a chevy 44 in your gear ratio? seems that would be cheap and easy. you should be able to pick one up for $100 - $150 easy. I think that they came stock up to 4.56 gear ratio - tho i think 4.10 is more common (that's what I got). seems like alot of work whene there's cheap alternatives. however, it would be fun to customize something like that. :)
    colby stephens.
  8. richheezee
    Dec 29, 2003
    116
    San Jose CA
    i was thinking of using the stub shafts and locking hubs on my original 10 bolt to convert. i figure i would just need 8 lug rotors, 3/4 ton backing plate, new u joints and new bearings.
    it's just a lead, basically i am thinking of buying it. how much are you looking for your 60? what gears? let me know when it's free since the price is dropping each day. LOL j/k
    if i could find a gm 44 in my area believe me, i would. i'm all for cheap and easy. LMAO yah, it does sound fun customizing a dodge 44 into my truck and it's 2 inches shorter so the front will be only an inch wider than the rears. i think. :o
  9. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    I get the impression that you'd like your axles to be the same width. is there a reason you want them to be the same? the narrower rear end will help decrease the turning radius - always good, esp. w/ offroad tight spaces. Also, it increases the amount of fresh terrain into which the tires can bite.
    colbystephens.
  10. marv_springer
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Errrrr...?!?
    Can you explain this?!:dunno:
    Marv
  11. richheezee
    Dec 29, 2003
    116
    San Jose CA
    nah, axle width doesn't really matter to me. all in all, this dodge 44 is an axle that is cheap and can be had by the end of the weekend which can help me complete my 3/4 ton swap sooner than i thought and get me back to the trail. :D
  12. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    i can definitely appreciate wanting to get on the trails/road again. my truck has been under construction since about may-ish, and won't be on the road until i think february. i'm getting ancy! ;)
    check out this thread: http://www.coloradok5.com/forums/showthread.php?t=154212&highlight=wider
    basically, if this makes any sense, it's putting your pivot point closer to the center of the width of the wheel base.
    colbystephens.
  13. onetonbb74
    onetonbb74 1/2 ton status
    Dec 1, 2005
    2,083
    Campbell, CA
    dana 44
    i have a dana 44 axle from a chevy with 4.09 with axle shafts and housing only and im in san jose if intersted email me
  14. richheezee
    Dec 29, 2003
    116
    San Jose CA
    email sent.
