mid 80's 14 bolt ff compare to a late 70's
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by one ton burb, Jan 6, 2004.
  1. one ton burb
    one ton burb 1/2 ton status
    Nov 15, 2003
    119
    Ontario, Canada
    mid 80\'s 14 bolt ff compare to a late 70\'s
    Ok I know gm did a few changes to the mid 80's 14 bolt ff so I want to know if they changed any thing in the pinion and ring gear set ups like the bearing sets or something. because i have a 14 bolt out of a 78 and i want to swap the gears with the onecs out of a mid 80's 14 bolt ff I found so if they did what would it take to make it work? thanks
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    Re: mid 80\'s 14 bolt ff compare to a late 70\'s
    the only change that i know of is the brakes in 87 or 88
  3. one ton burb
    Nov 15, 2003
    119
    Ontario, Canada
    I know about the brakes but i read someware on pirate 4x4 that there is something diffrent in the pinion bearing set up or something like that. and i can't seem to find it again. So just want to make sure before I buy anything
  4. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i just checked the bearing part numbers and they are the same except for the pinion bearing . they are the same from 72 to 87 and are different from 88 to 97.
  5. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    Somewhere around 1988 GM ( or AA ) changed to a ribbed center section and started using a different pinion bearing in the pinion retainer . The large pinion bearing is larger on the newer stuff . You can use an older pinion support in a newer housing ( and visa/versa ) if needed .
    Tom
  6. one ton burb
    Nov 15, 2003
    119
    Ontario, Canada
    ok thanks man i was preaty sure they did change it just i was not sure what year they did the change in /forums/images/graemlins/rolleyes.gif so thanks a lot /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
