Mid 80's Engine questions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Big_B_Murphy, Jan 2, 2002.
  1. Big_B_Murphy
    Big_B_Murphy 1/2 ton status
    Dec 28, 2001
    159
    New Stanton, PA
    Mid 80\'s Engine questions
    What year did chevy go to the center bolt valve covers? Also when did they go to the serpentine belt setup? Is there any easy way(without yanking and disassembling) to check the block to see if this stuff was added to an older block. I am contemplating an auto to stick swap (TH700 to SM465) and I am reading that somewhere in the mid 80's chevy changed to balancing externally. What year did this happen?
    I am much more familar with Chevys of the 70's where everything was pretty much interchangeable. I had done this swap on a 77 K10 with no problems, so I am just curious what to look for on the flexplate as far as weights.
    The more I dig in to my 85 K5 project, the more it seems like a jumble of what someone had laying around.- probably why I got such a clean bodied truck so cheap.
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    Re: Mid 80\'s Engine questions
    The center bolt V-covers came in '87...... The serpentine came at the same time or around 88.....
    Not sure on the externally balanded issue, but I thoguht all 350's were the same throughout the years... I think the 400's were the only engines that were different..
    Mike
    <font color=green>"My K5 is purdyur than your sister!"</font color=green>
    <a target="_blank" href=http://www.geocities.com/emmettology101>www.geocities.com/emmettology101</a>
  3. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    I'm sure you can get an appropiately balanced flywheel for your setup. The only way to verify the block itself is to pull casting numbers, and cross them. I think that most trucks started getting the "center bolt" heads in 87-88... but I might be wrong.
    As for the state of your truck, isn't everyone's truck "just want they have laying around"? [​IMG] My truck has so many different parts from so many trucks... I need a dozen manuals to keep up with everything!!! [​IMG][​IMG]
    <font color=red>GOT MUD???</font color=red>
    My license plate reads:<font color=blue> 8 YR SUV</font color=blue>
    454/TH400/NP205 - 14BFF/D60/w/ 4.10s - 36" TSLs
  4. shawnboy
    shawnboy 1/2 ton status
    Jun 22, 2001
    468
    Toronto, Canada, eh.
    I may be wrong but I think the serpentine belt arrived in 1989 and the centre bolt valve covors in 1987 or '88. I'm not sure about the balancing. You can get kits to do a serpentine install.
    Shawnboy.
    <font color=red>If you are having too much fun it's probably illegal.</font color=red>
  5. rodzzilla
    rodzzilla 1/2 ton status
    953
    Grinnell, IA
    '87 Is when they switched to centerbolt. I think that is when they went to the 1pc rear main seal. That is when they started with the different flexplate/flywheels. The end of the crankshaft is round on the 1pc seal engines. I am not sure what weights they put on the flexplate/flywheel.
  6. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    The 87 at my house has centerbolt valve covers and no serpentine belt.
    350cid is internally balanced.
  7. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    86 was the new one piece seal. You can use an 85 2-piece unit in an 86 with a different flexplate.
    Brian
    Check out <a target="_blank" href=http://tx85gmcguy.alloffroad.com>My Jimmy</a> with all her projects!
  8. 3car
    3car 1/2 ton status
    Dec 16, 2001
    976
    Hernando, Florida
    i had 2 88 k-1500's ,both were serpintine belted,i have an 87 caprice with v belts.
    eatin'fords and shittin'dodges down in the sunshine state.
  9. Big_B_Murphy
    Dec 28, 2001
    159
    New Stanton, PA
    All thanks for all of the info. It is true that the only good truck is a truck that you build you self. I just happened to break one of my major rules about buying a truck that has been modified by a source that I did not know or trust.[​IMG] (The previous owner is now actually dead).[​IMG] I was initially bit when the supposedly rebuilt tranny went within two months of buying the truck. It is an 85 and the engine has both center bolt covers and serpentine belts. The previous owner even had the wrong cooling fan on the truck that was blowing air into the radiator.[​IMG] I just wish he was around to piece the puzzle together for me. Oh well nothing like a challenge.[​IMG]
    I love the truck and bought it anyway. Like I said the body was too good to pass up for the price. (I grew up in the rust belt).
    Thanks again for the info. I enjoy piecing the puzzle together as much as the finished product.
    <font color=red> It is just as much fun to build it as it is to bash it</font color=red>
  10. jwduke
    jwduke 1/2 ton status
    Aug 25, 2001
    721
    Ice Cream Capital of the World, IA.
    '87 on the center bolt valve covers, '88 on serpentine belts, &amp; '87 on 1 piece rear main seal. This is according to the Hollander interchange manual. 400 &amp; 454 are externally ballanced, everything else is internally ballanced. (Of regular production engines)
    1 ton '87 Chevy SWB in the making!
  11. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    all the one piece seals are external, they carry wieght on the flywheel = external
    formerly 77chev
