Mid-build on the sliders... *NEED AN IDEA RE: POST #3*
Discussion in 'The Garage' started by colbystephens, Dec 24, 2006.
  1. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    so supersize86k5... or whatever the heck shawn's screen name is... wanted to help me (read, do most of the work while i wished i had the skills to help) build some sliders into my truck. my door sills were a bit rusty, so we decided to cut the door sills out and really improve my ground clearance under the body. we got one side mostly finished today, but no pics of it in the semi-finished state.
    the rectangular tube is welded into the body, and braces will be made which go to the frame, which should help body flex a bit, which will be nice since i'm running a mechanical clutch pedal.
    the pics are in teh following order:
    • before
    • the shop cat
    • during, after the cuts and the box tube is mocked up in place
    • welding
    • showing the space created
    • filling the space
    these are also intended to help ward off trees a bit, but they don't stick out too far, so they won't be of much help in this area in many cases, unless the doors were removed. this requires significant door modification, which was nice because i got to get rid of even more rust. the one door we've done so far, we just cut straight across the most inside panel a couple inches below the line under the vent (essentially even to one inch below the hinge.) then the outside is another inch or so below that. we will weld in a panel to fill the hole under the inner panel of the door.
    when we do the second door, another method will be considered, where instead of cutting straight across the bottom of the inner-boxyness of the door (sorry - lack of better words, the part where the window goes into), we'll cut just a bit under neath, and then try folding the box back to the door and welding it - this should make it easier. i'll post pics so you can understand.
    i plan to paint them army green, which is the color i intend to do the tube bumpers/cage when i get to that point. should be a real nice color scheme. :D enjoy the pics. i'll do some before/after shots when we finish on Tuesday nite.
  2. NateInChandler
    NateInChandler 1/2 ton status
    Apr 23, 2006
    418
    Chandler, AZ
    that looks good colby, just be glad you can get him to do something for you. as i hafta threaten him to get him to help me.. HAHA, looks good man, was nice wheeling with you and claire and i hope to see youguys again.. nate
  3. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    need an idea!
    i was thinking it would be cool to fab up some way to attatch a D-ring to each slider such that if winching from the side were ever necessary, i could attatch there. how could this be done w/ out sacrificing the smoothness of the surface and thereby the slider effect of the unit?
    i've got a couple of hooks - maybe i should drill two holes in the side of the slider near the front and rear of the slider so that my hooks could be placed in such a way as the hook would stick out of the tube when needed for pulling, but could be removed easily so as not to sacrifice wheel-space for flexing. hmmmm. now i've got a couple other ideas for that too. i could leave the bolts in the holes when the hook is removed so that the structure of the slider is less affected. perhaps this structure is only more important near the front tires, as this would proably recieve the most thrashing - coming down off of a rock real hard or something. what thoughts do you all have??
  4. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    another idea! maybe if i have a cap built on each of the ends of the rectangular tube, i can drill holes in the cap and have nuts welded to teh back of the cap so that the hooks can be removed and re-installed as needed. that sounds better than my other ideas.
  5. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    why not make them pin-able like a hitch? 2 2" square holes that you can put a hook into...
  6. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    ahhh - that's a better idea! no bolting/screwing reqd!
  7. Confedneck79K30
    Oct 1, 2006
    5,384
    LA
    cuz they make round hooks that are built off solid 2" stock to fit in a hitch hole drilled and all, all you need is a gusseted, sleeved 2" opening for them, post pics!!
  8. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    Shawns workin on Colbys truck...i bettin on 2 months...any takers?
  9. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    :hack: :weld: :grind: :hack: :hack:
    bwhahahahaha:haha:
    :yikes:
  10. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    :haha: :haha: :haha: :haha: :haha:
  11. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    so i just measured, looks like this raises the clearance of the body by 4" when you put the top of the 2" thick tubing at one inch below the bottom hinge. :)
    couple shots - still not done, finishing tomorrow nite, but it gives you a good idea.
  12. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    looks good
  13. KGsK5
    KGsK5 1/2 ton status
    Aug 26, 2006
    343
    Havre de Grace, Maryland
    looks good. and didnt seem all that difficult. how hard was it to make the doors fit?
  14. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    doors are the hardest part - i'll get back to you after we do teh second one b/c it'll be different and possibly easier.
  15. KGsK5
    Aug 26, 2006
    343
    cool thanks
  16. MaxPF
    MaxPF 1/2 ton status
    Apr 13, 2006
    2,207
    Chandler, Arizona
    Looks great! Maybe I'll cut my rockers out :hack: :eek1: :ignore: :haha:
  17. Chrisblazzer89
    Chrisblazzer89 1/2 ton status
    Oct 12, 2006
    1,966
    Massachusetts 02301
    I was wondering if u had pics of the welds cas i want to do something like this and need a good boast in the right direction
  18. supersize75k5
    Feb 3, 2004
    8,832
    4
    gilbert az
    phase 2 in progress..
    its 3 am and he leaves at 9am for the grand canyon..
    I think he is as crazy as I am..
    :crazy:
  19. supersize75k5
    Feb 3, 2004
    8,832
    4
    gilbert az
    5:20 am... still working! goal is to be done in one hour. :D
  20. supersize75k5
    Feb 3, 2004
    8,832
    4
    gilbert az
    well colby just left at 7:30..
    I ended up with a nast piece of metal in my eye and yes I was wearing goggles, so off to the doctor I go this morning:( pretty big piece.
    damn it took forever it seems, I am walking dead right now, alot of work since we cut and raised the door bottoms as well:crazy: l
