MIG or TIG
Discussion in 'The Garage' started by dontoe, Jan 20, 2005.
  1. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    I have an old stick welder. I'm looking at getting a small wire feed welder for sheet metal and small stuff. What do I want? TIG or MIG. What are the differences and which do I want? Maybe max of $500.00 to spend. I have 220 Vac but 110 Vac would be more convenient. I think I saw an under-hood 12 Vdc once in a magazine a few years back.
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Your not going to get a TIG welder for $500. Plus you have to know how to TIG weld to do it. It is totally different then stick welding. If you can stick weld then you can MIG weld. Get a MIG welder that will run gas. For welding sheetmetal you will want to run gas with .023 solid wire. You need to be able to adjust the settings way down too so you don't blow holes in it.
    Harley
  3. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    Go for the mig , tig is nice but not needed for most fab work
    The old saying you get what you pay for comes to mind , but I have been spoiled at work by high dollar welders
    Bigger is better , get the best you can reasonably afford
    These are just my thoughts...
  4. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
  5. big jimmy 91
    Feb 21, 2004
    639
    I think that machine would be ok for light duty use
    20% duty cycle is kind of poor but if your not mass production welding ,who cares
    Being capable of mild ,alum. ,stainless welding is good
  6. sweetk30
    Nov 1, 2004
    25,537
    536
    horseheads , ny 14845
    i have the hobart 140 unit . it runs on 110 20amp circet. it ROCKS . it will weld the hell out of anything i need and about your price range. to bad you dont live closer . i have a inside contect at a supply store and i got my unit for about 125 less the retail price. its the best money i ever spent. p.s. its the off brand of miller, and some of the components say miller on them.
  7. gmchevy
    gmchevy Registered Member
    Apr 14, 2004
    28
    North Carolina & Colorado
    If you plan to do any welding outdoors will be better off running flux cored wire. Any breeze will blow your gas.
  8. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    I don't know anything about TIG, but MIG is very easy to learn. I'm not great by any means, but I am getting better and it was very easy to get started.
  9. dirtwarrior17
    dirtwarrior17 Banned
    May 14, 2004
    1,820
    Redding, CA
    a mig welder can do everything a tig can and its easier. They have aluminum/steel mig welders for about 600.
  10. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Yes, MIG, like everyone said. A TIG probablly wouldnt be needed. Although, I do like TIG welding more then MIG.
  11. gmchevy
    Apr 14, 2004
    28
    i have a lincolin 100 amp set up for flux cored, runs off 110, and it will handle 1/4 inch no prob. I also have a hobart 250 with gas in case the little one just can't burn it. You can get a 100amp mig at lowes or home depot for about $450. honestly, unless your going to do it for a living that will be all you need.
  12. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    99% Inside
    I'm gonna have a 30X30 steel building built before spring (Lord willing) and all welding will be inside. Can I get the $450.00 welder and upgrade to aluminum welding capability later? And isn't the gas one better?
  13. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Most wire feed machines have a kit available to be converted to gas (even the $150 harbor freight ones). All you need for aluminum is the special aluminum wire and pure argon shielding gas. TIG is over rated. It is nice but totally useless on mild steel thicker than .095" There is a kit for the lincon (sp) buzz box stick welder machine. It will convert the machine into a TIG machine.
  14. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    mig without a doubt.
  15. rusty_82
    rusty_82 Registered Member
    Oct 21, 2004
    18
    Southern NH
    I have a millermatic 175 MIG and a Synchrowave 180SD Tig and when working on trucks all your gonna use is the MIG, and mig will not do anything TIG will do. My tig can weld steel, aluminum, copper, stainless, magnesium and titanium.
    -Stew
  16. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Agreed 100%, this is what I have, paid less than $300 for it used shipped to the door on the internet and it is absolutely flawless. I have even welded 1" plate with it in multiple passes with flux core wire.
    MIG will do everything I WANT to do that TIG will. TIG makes prettier welds and will weld stupid crap like stainless, aluminum, etc. I don't care as I only weld mild steel and the MIG I have does EVERYTHING I have wanted it to do, to date.
