MIG welder suggestions
Discussion in 'The Garage' started by fad2blk99, Mar 30, 2004.
  1. fad2blk99
    fad2blk99 1/2 ton status
    Feb 19, 2001
    860
    Charleston, SC
    What is a good welder to get? I want an inexspensive MIG that can reliably weld up to 1/4" plate steel.
    /forums/images/graemlins/ears.gif /forums/images/graemlins/ears.gif /forums/images/graemlins/ears.gif
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Hobart 175, EBAY
  3. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Lincoln SP-135T. EBAY (new)!
  4. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I have a Lincoln sp-135 PLUS. I love it for what I do...If you want do do 1/4" A LOT, get like a Lincol Power MIG 200 or 255...
    I am looking at geting a PowerMIG 300 so I can do EVERYTHING
    Chirs
  5. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    stick with a lincoln or miller... sp 170t is a relaible small 220v welder that can do what you are asking... the 135 is a little down on power.
    the hobart isnt bad and there are a bunch out there but Ive always wondered about a company that makes welders and bakery mixers?
    cam
  6. heavy4x4
    Aug 28, 2002
    3,270
    Oh, and if all you're going to be welding (or a majority anyway) is only 1/4" plate steel, hell, get a less-expensive arc welder.
  7. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    SP135T if you don;t mind the extra work of flux core
    220v 175 or so if you want to use gas
  8. scoutillac
    scoutillac 1/2 ton status
    Feb 24, 2004
    423
    Spokane, Wa.
    Lincoln SP135+ The best investment I ever made for the shop. Besides the garage itself.
  9. heavy4x4
    Aug 28, 2002
    3,270
    But, it's already set up for running gas...all you need to do is get a bottle. In fact, it's set up from the factory to run solid-wire (comes with solid wire and the proper sized tips). To go to flux core, you have to buy the flux core wire and larger tips.
  10. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Miller or Lincoln for me. I have a Miller 135 or something. Small but it's okay. /forums/images/graemlins/dunno.gif
  11. scoutillac
    Feb 24, 2004
    423
    Spokane, Wa.
    I like being able to use gas for sheet metal or flux core for some heat on the thicker stuff. Reverse the polarity and she really cooks hot. My breaker doesn't like it for long though.
  12. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I have the Lincoln SP-135T Plus and use the thing to death without any problems. Even bought it for a really good deal. $249.99 /forums/images/graemlins/yikes.gif
  13. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    I have a century mig welder with argon, its ok and fits my needs. /forums/images/graemlins/smirk.gif
  14. grd2go
    grd2go Registered Member
    Mar 28, 2004
    55
    Anchorage Ak
    I have a lincoln sp255 mig welder I love it I build things for our fleet of 9 tow trucks, 4 plow trucks and my three chevys that I use for everday drivers. I have never had any problems with it and Im now on my 5th 30lb spool of wire and just refilled my tank for the first time granted I do have the biggest bottle I could get for it but it lasted almost 2 years so its all good.. Try sticking with lincoln are miller they are by far the best on the market and easist to get parts for. /forums/images/graemlins/cool.gif
  15. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    ok
    how does an arc welder work
    and whats the downside of flux core?
  16. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    The downside of fluxcored welding is the welds have more spatter and there is more cleanup involved. Gas shielding provides nice CLEAN welds. For most stuff I use gas shielded un less I am outside in windy conditions or am welding at eh uper limit of my welders capacity...
    Chris
  17. fad2blk99
    Feb 19, 2001
    860
    Charleston, SC
    Where did you score that!!! Sears has an SP-135T (no plus-if thats any different???) for $470!
    the Hobart isn’t bad and there are a bunch out there but Ive always wondered about a company that makes welders and bakery mixers?
    cam
    Hobart also makes the diesel generators the military uses to provide 3-phase, 110 VAC, 400Hz electricity to power aircraft electrical systems on the ground (so that we don't have to run the aircraft engines or APUs). And, we beat the hell out of these things (starting them up and going to build-up voltage with no warm-up, shutting them down from w/o throttle w/o a cool down and basically running these things all day and night in blazing heat and/or torrential downpours until they run out of gas). Believe me, if these things are any indication of the rest of the companies products, then Hobart must make a mean blender!
  18. fad2blk99
    Feb 19, 2001
    860
    Charleston, SC
    I didn't see it... gotta link?
  19. scoutillac
    Feb 24, 2004
    423
    Spokane, Wa.
    [/ QUOTE ] Put a wire cup on your 4 1/2" grinder and the slag disappears instantly. /forums/images/graemlins/grind.gif
  20. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    Ive got a Lincoln SP 170T and am very happy with it. /forums/images/graemlins/thumb.gif
