mig welders
Discussion in 'The Garage' started by poolcues, Dec 16, 2006.
  1. poolcues
    poolcues 1/2 ton status
    Dec 13, 2004
    232
    Charlotte,NC
    looking to buy a mig welder. more specifically wanting to know the advantages and disadvantages between the tap control and continuous control.gonna be used for light fab work and sheet metal work.did a search and didn't turn up much.
    thanks
  2. Insomnya3AM
    Insomnya3AM Registered Member
    Jun 12, 2006
    29
    Detroit
    I'm a welder and I've never heard of continuous vs. tap. All the MIG welders I've ever used, you need to hold down a button on the gun while you are welding.
    Get yourself a Miller, make sure to get one with gas, no flux core, and start practicing!
  3. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    Tap is 4 heat setting for voltage control. The slightly more spendy models have infinite voltage control which is far superior IMHO. I would not have bought my Millermatic 135 if it had 'tap' for voltage control.
    Being able to fine tune the voltage is crucial and allows you to make much better looking welds.
    Rene
  4. Insomnya3AM
    Jun 12, 2006
    29
    Detroit
    I see what you're saying. I've always gotten along perfect with my couple of 'tap' MIGs. All machines have infinite wire feed control, so to 'fine tune' it, you set the voltage to as close as you want it and either go faster or slower along your weld.
    IDK - It's a matter of preference.
  5. poolcues
    Dec 13, 2004
    232
    Charlotte,NC
    sounds like continuous control allows you to reduce "booger" welds also.
  6. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Mine is a Tap (Lincoln 175) which works fine for what I do. Seems like most guys who do more detailed work go with the infinite. Go look in the Tool Shed section. This has been discussed several times.
  7. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    at work i have a continous control (with a digital readout), while at home i have a tap control. there are times that i wish i had continous at home after using the one at work.
    sometimes i feel it is needed for what im welding, where most other times i never have to touch it. it is nice to have though.
  8. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    I'm also spoiled with the machines at work...which was probably why I was so set on the infinite voltage feature.
    Rene
  9. poolcues
    Dec 13, 2004
    232
    Charlotte,NC
    with all that's been said it sounds like continuous is the way to go.
