might be busting out the stick welder this weekend. any tips
Discussion in 'The Garage' started by down4thakrown, Aug 12, 2005.
  1. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    im goin to do some welding this weekend or atleast some practicing with my dads stick welder while he goes to work. what should i set it at if im goin to be welding some like 1/8" thick steel to the frame? i know it helps to grind where your goin to weld but, anybody got any other tips?
  2. foolhardy
    foolhardy Registered Member
    Sep 16, 2004
    84
    humm i would use 7014 sticks easy arc starts
  3. diesel4me
    Jul 24, 2003
    17,553
    939
    Massachussetts
    a few things...
    I usually use 6011 rods,because most of what I weld is rusty up here in the salt belt..its strong enough for most repairs,and is easy to strike and keep an arc with,and is very forgiving if the work is dirty,painted,or a bit greasy..
    Be sure to disconnect your battery cable before Arc welding anything to your truck!...I blew a nice 300 watt amplifier up in my van by forgetting to take the ground cable off first! :doah: --it can fry diodes in your altenator,kill your computer,or blow your bulbs if you neglect to do this!...doesn't happen every time,but its cheaper to take the battery cable off!.
    I'd practice on some scrap steel first,until you get comfotable with your beads,and where to set the welder..(I usually weld at 75-90 amps,depending on the thickness)...A good mask/lens is a must,or you'll feel like you had sand thrown in your eyes when you try to sleep tonite!... :crazy:
  4. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I would try around 90 amps at first. You can tell right away if it's too "hot" then turn it down some. I welded my truck bed/trailer tounge with 7014 rods on 105 amps with no metal prep of any kind, and it did ok even through rust and paint. I'm no pro, so don't laugh at my welds.
