Might sell my custom bumper
Discussion in 'General Parts for Sale' started by babyburb, Mar 30, 2007.
  1. babyburb
    babyburb 1/2 ton status
    Oct 24, 2006
    2,344
    1H North of Dallas
    I am thinking about selling my front bumper that I am currently building. Reason being I will be doing a body swap pretty quick and going to move the winch behind the grill. I would use my current set up but it is already bent at the angles and welded up so I figured it would be eisier to just start over. This winch/ bumper has already pulled out 7 vehicles, pulled down several really big trees, and uprooted a 1 ton truck from being buried in the ground after 40 years. It is Heavy and stout. I also have put a 16 ft loaded trailer and used it to pull a big feeder hopper onto the trailer and moved it around my place.
    I am willing to sell it different ways and would be up to the seller what he would want to do.
    1. $200 take it as is and you finish it like you want it.
    2. $225 filling in the side triangle void with expanded metal
    3. $250 filling in the side triangle void with 1/4 in diamond plate
    I would also cut and add a 6in fender wrap on both corners for an exra $25. If not I can cut them off even with the truck and cap the end for free. I plan on cutting the winch plate down even with the frame brackets and rounding the corners off. I also plan on capping the cutout for the roller fairlead as well. The two inch recievers have hitch pins drilled vertically and the ends were wrapped with a 1 in strap.
    I really would perfer not to sand and paint but I could have them sand blasted and painted flat black for another $50
    No shipping! I could meet North of Dallas Ft WOrth. Denton or SHerman also.
  2. m1ndless
    m1ndless Banned
    Feb 18, 2007
    642
    Phoenix, AZ
    Is the winch included?
  3. babyburb
    Oct 24, 2006
    2,344
    1H North of Dallas
    I knew that question was going to be asked when I posted and should have included, but no, winch stays with me.
