MileMarker hubs suck A$$((Here is what I broke))
Discussion in 'The Garage' started by SCOOBYDANNN, Apr 23, 2002.
  1. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    Going up a wee little hill, not even on the gas---just 4lo and granny---POP!---eh, it was just the locker----NO, the tire isnt turning. DOAH!!!!! get home, tear apart the hub-----stripped teeth on the inside------guess that means i need to upgrade to 35 spliners /forums/images/icons/smile.gif---just had to rant, thank you for listening
    updated pics
    http://community.webshots.com/album/36478194drQmSS
    Dan
  2. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    Re: MileMarker hubs suck A$$
    get some warn premiums... they are about as good as any imo.
    J
  3. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    I have heard a similar story before but never had problems with mine.
    Seriously grab a brand new milemarker and some brand new warn hubs while you are at the auto parts store. Look at the internals Almost identical! Designed by the same people! Premiums in my opinion are just a shiny cover on top of the same internals. Buy what you want but just check it out anyway its interesting.
  4. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    <blockquote><font class="small">In reply to:</font><hr>
    <hr></blockquote>
    I must agree..
  5. Lotsa_Faith
    Lotsa_Faith 1/2 ton status
    Jul 10, 2001
    474
    Mckinney, Texas
    What's the diff between warm premiums and regular warn hubs?
  6. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    the outer knob.
    i thought MM were stell body?
    you stripped it and think the potmetal warn junk will be tougher?
  7. SCOOBYDANNN
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    I stripped the outside of the collar that slides on the shaft (if that makes any sense) do you think i can just buy that peice?
  8. BowtieBlazer
    Jul 15, 2001
    2,462
    Nope! Hubs preety much come as hubs or hubs....I have seen rebuild kits that come with new screws and two o-rings but thats about it.
  9. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    If I were you, I'd get the Warn Premiums and install their hub fuses.
  10. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    Warn Premiums also have a lifetime warranty, so if they do break, take them back and get a new set. Pretty good deal IMO. Premiums are all metal too.
  11. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    If the Warns have a lifetime warrenty, then why spend the money replacing the hub fuses when you can just have Warn replace the hub free of charge?
    Ken H.
  12. Grim-Reaper
    7,385
    Atlanta
    The super wench hubs are not a bad design for the price.
    Hub fuses are a double edge sword. WIth the wheels turned the fuse may not blow before the U-Joint fails. On the other end is the locker. There have been MANY reported cases where when the fuse blew the slam that the locker takes as a result will bust the locker.
  13. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    Chances are the situation where the hubs failed was simply the point they let go after being damaged by a previous incident, or multiple previous incidents. It' s just like the people who say their 10-bolts blew up just by simply backing out of the driveway, in reality they were pushed to the limits and the previous fourwheeling trip or by the burnouts from the previous weekend. The parts were just barely hanging on and a little bit more stress and fatigue was all it took to finish them off.
  14. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I agree. I personally prefer MMs to Warns, but not by a huge margin. I wouldn't go out of my way for or against one or the other. However, all other things (price and availability) being equal, I would choose MM...
  15. SCOOBYDANNN
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    This does make sence----but these hubs were 2 months old and been on one decent trail, and about 4 other times where i even put it in 4.
  16. Re: MileMarker hubs suck A$$
    I dont know about the Super Winch hubs because I had a set up until last week, when I somehow managed to strip it out. Also if you look inside the SW ones one of the bigger parts is plastic! That part had cracked on mine which allowed there to be some play in the hub which then stripped out the big ring piece. I think it's really funky to make a part of a 4WD hub plastic. I got a set of Warn Premiums and have not had a problem yet, plus it's real nice seeing everything in there metal /forums/images/icons/smile.gif 80K20
  17. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    It says right on the hub fuses package, that hub fuses are not ment for locked axles. So if someone put hub fuses on a locked axle, they are either stupid, or willing to take the chance the locker won't blow. It is there own fault the locker went.
  18. BILLY RAY
    BILLY RAY 1/2 ton status
    Dec 8, 2001
    1,319
    Austin, Tx.
    HEY DAN RUN THE WARN I HAVE HAD A LOT LESS PROBLEMS WITH THEM. CARRY THAT METAL FULL TIME HUB WITH YA ( I FORGET THE NANE OF THE PART) YOU KNOW THAT COMES ON THE FULL TIME FOUR WHEEL DRIVE ONE TON TRUCKS. SO WHEN YOU BREAK A HUB YOU CAN PUT THAT PART IN AND FINISH THE RUN.
  19. SCOOBYDANNN
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    carry the whole hub, or just the internals. Ill look into those if i end up not getting the 35 spl
    ya know---i bought the damn 60 so i wouldn't be braking stuff-----if I was doing something like farmington or Las Cruses id be "OK" but come awn, the is the local testing place. oh well---time to look into the 35 spline and warn stuff.
  20. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    the working parts of the premium warns are the same hub as the standard warn IIRC.
    can you shoot and post a pic of the damage?
    would be nice if someone would step up with an actual premium hub rather then a shiny coating on pot metal.
    need a cnc guru to whip out some super hubs, of course the hardcore just run drive flanges
