MileMarker Hydraulic Winches
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by smartpatrol, Mar 12, 2002.
  1. smartpatrol
    smartpatrol Registered Member
    Feb 6, 2002
    86
    Ault CO
    Anyone running one? I haven't bought a winch yet and the hydraulic winches are more appealing than the battery powered ones at this point. However i value anyones opinion on the pro and cons of such a winch.
  2. Stomp
    Stomp 1/2 ton status
    Feb 23, 2002
    168
    Hill Air Force Base Utah
    Hydraulic+motor not running=no winch power
    The biggest con
  3. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    Right, but that is pretty much the same problem with an electric winch too, right? If the engine is off, what battery(ies) can keep up with that kind of draw?
  4. Stomp
    Feb 23, 2002
    168
    True. As far as draw and battery power, I guess that depends on how far you have to winch. Some winch is better than no winch
  5. Dieselmh
    Dieselmh 1/2 ton status
    910
    Texas
    You could also get an aux. electric pump to run the winch if the engine dies, but you're still relying on battery power then. I don't have any good info, but I've been checking out the Milemarkers too.
  6. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    From what I have seen on the trail the typical winch pull is probably only 5-10 feet. If your battery is in good condition it should have no problem pulling that distance, or further, and still be able to restart the engine. A perfect example is during a rollover recovery or if you drown the engine out in a mud hole.
    All in all, I've just seen too many non-running vehicles use their electric winch during recovery to ever want a hydraulic.....for trail use anyway. For work or farm use when sustained pulls are necessary, than a hydraulic might be better.
  7. hammer
    hammer 1/2 ton status
    Aug 29, 2001
    449
    Binghamton N.Y.
    if you are rolled over or you are in a mud hole isn't there somebody else to pull you out if your engine is not running. with electic or hydraulic you would have this problem. but for long dytycycle time like for farm work wouldn't it be better to have hydraulic. I was looking at the mile marker hydro winch also
  8. smartpatrol
    Feb 6, 2002
    86
    Ault CO
    Thanks for all you input so far. SInce the milemarker winches are roughly the same price as the warn winches. It seems they may be a decent alternative.
  9. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    hey, anyone know if running a hydro winch precludes the possibility of using hydro-boost steering?
    J
  10. Grim-Reaper
    7,385
    Atlanta
    SLOOOOOOOOWWWWWW WINCH....Did I mention just how SLOOOOOoooooowwwwww they are? They are real slow.
    They also have a VERY nasty habit of jumping into Free spool. After knowing somebody with one that duped it for electric.....I won't buy one. They also tend to fry power steering fluid even with a cooler.
    A big issue when wheeling is often the truck will catch traction and if you stay in it you no longer need to winch but the slow winches you run the real possiblility of driving over the cable. I have seen it too often. If you had better line speed then you could have gotten out quicker but had to stop to keep from running over the cable or bird nesting the cable because it lost tension. I'm getting a HS9500i. I would get a 8274 but my winch bumper will not occomidate it.
  11. smartpatrol
    Feb 6, 2002
    86
    Ault CO
    Defintely nasty cons. Thanks
  12. 85m1009
    85m1009 1/2 ton status
    Jul 11, 2000
    718
    Missouri
    Been running one for several years and like it! It runs fine with hydroboost. I know that I am in the minority but just my 2 cents.
  13. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Do a search on this one, there's been a lot posted on this in the past.
  14. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    Maybe really a matter of what type of wheeling you do. (Us) mud guys really want/need extended duty HD winching (I've seen axles dislocate getting dragged thru the gumbo). Rock guys want fast line speed to get unhung without birdsnesting, operational even if they're on their head.
    I'm really surprised no one fabbed up a winch with it's own small engine. Two cycle could run at most any angle, alot more H.P. than any electric, line speed to keep up with anyone, and no cooked solenoids/motors. Just the thing for those Triatholon events!
  15. smartpatrol
    Feb 6, 2002
    86
    Ault CO
    Very cool idea i bet it would not be that hard to mount a weed wacker engine to one.
  16. if you are going to have the motor running to winch why not go PTO. i had one on my old heep and it kicked ass. i found a place that sells the drive unit for my 203 so i'm leaning that way.
  17. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    8000# winch is on the small side for a truck
    never seen the 8274 in action but i doubt the line speed is so fast as to outrun the truck
    get the 'spotter'/copilot to grab the line when it goes full slack
    I would rather have a slow winch that really pulls then a fast winch that barely pulls
    kinda in the same boat as an impact wrench that cant loosen the tight bolts, whats the point
  18. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    PTO hydraulic pump is the way to go
    PTO driveline looks like a PITA
  19. haven't heard of those? more info. got any links?
  20. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    <a target="_blank" href=http://www.munciepower.com/main/PTO.htm#FA>muncie</a>
    these guys are big name
