MileMarker Hydraulic Winches???
Discussion in 'The Garage' started by OffRoader93, Oct 6, 2003.
  1. OffRoader93
    OffRoader93 1/2 ton status
    Nov 30, 2002
    262
    Do hydraulic winches use the existing power steering pump or do you have to add one? Thanks.
  2. yeild2me
    yeild2me 1/2 ton status
    Jan 7, 2001
    1,309
    fayetteville, nc
    yes. they use the stock one
    ...they are very SSSLLLOOOOOWWWWWWWWWW>......Then when you put them in high, they hardly have in power. Buy an electric....
    Rob
  3. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    They can use a stock PS pump, as long as your pump is in good shape. As for the speed-
    My stock one does fine. I dont find it any slower compared to any other ones that do the same weight. (with the exception of the 8270, or whatever warn model that is). High speed is faster than any electric that I have seen (Im sure there are faster ones) and low speed is pretty darn slow, but under a full load, the hydrolic one barely slows down. thats the true beauty of the MM hydro winch. It doesnt konk out under extremely hard and heavy use.
    If you are really worried about the speed, you can get a High output power steering pump and an inline cooler.
    This link below will give you a rundown on the different pro's and cons of each winch.
  4. rugger03
    rugger03 1/2 ton status
    May 14, 2000
    829
    around
    pook no link
  5. 89BlazerK5
    89BlazerK5 1/2 ton status
    Aug 24, 2002
    134
    get the winch test free video that Mile Marker did. it's pretty neat.
  6. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    ...and totaly unbiased
  7. K5BLT4FUN
    K5BLT4FUN 1/2 ton status Premium Member
    Feb 28, 2000
    496
    Peculiar, MO USA
    I presently have a MM 10500 lb. winch on my 88 Blazer. It is connected to a new power steering pump. Yes they are slow speed winches, but I don't see where that is a big issue unless you are competing and time matters. Mine is a 2 speed winch. As stated earier the high speed is much faster, but has less load capacity. I have used mine to move a Mobile Home, that had triple axles and was buried up to the frame in mud. Had to move it over 100 yards to solid ground. I had to use a snatch block to get it unstuck, but after that it was just a matter of backing up and the reeling it in. I had to use mine in Moab to pull myself and another blazer up several walls that were nearly vertical. I liked the fact that it was slow then, much better control. Just my experienced opinion. The only real short fall of the Hydraulic winch is, if the engine is not running then neither is the winch. An electric will possibly get you out of a situation if the engine died, but for long duration, heavy duty use, I will stick with my MM Hydraulic. /forums/images/graemlins/thumb.gif
  8. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
