Military Beadlocks
Discussion in 'The Garage' started by MrArmyAnt, Apr 27, 2006.
  1. MrArmyAnt
    MrArmyAnt 1/2 ton status
    Dec 29, 2004
    662
    Texas, Kick a$$! (Grapevine, DFW; also Norman, OK)
    Ya'll say backspacing is like 7 inches, why couldn't you just turn the wheel around? Wouldn't you get two or three that way? And who sell good cheap spacers?
  2. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    They are not flat on the outer side of the wheel.
    Also, turning them around would push your tire way out, which would make your tires scrub alot when turning, and would probably play hell on your balljoints/kingpins and wheel bearings. Not something I'd want to do.
  3. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    There is the issue of the tapered surface the lugnut seats into. But maybe if you used one of the rings that go on with dully rims. I've thought about doing that, but spacers or wider axle is probably a better choice.
  4. Jishory
    Jishory 1/2 ton status
    Jan 8, 2002
    1,367
    Palmdale, CA
    it would make it a real pain to access the nuts that clamp the 2 piece wheels together if need be
  5. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    Besides for the issue that the wheel centers are stamped to go on a certain way (lug holes are stamped a certain way).........if the wheel is 8.25" wide and the backspacing is 7", if you turned the wheel around it would be the same as 1.25" backspacing.
  6. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    The centers also push out, when you flip them around they will rub the piss out of the brakes. This is done for rigidity and keeps people from actually getting their wheels on backwards.
  7. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    get a dually set of axles like Mike did. Do a search for MTMike
  8. MrArmyAnt
    Dec 29, 2004
    662
    I already have 14 bolt and 44 off a k20 :(
  9. MNorby
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    doh. Prob wheel spacers or recentering rings from usa 6x6 or something. I think they are fairlt cheap and sound easy to install. We were gonna go that rought on Mikes before we found the 1-ton dueally axles.
  10. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    You can get new wheel centers from *gulp* usa6x6 for pretty cheap. Otherwise Stazworks sells really nice ones, albiet expensive.
    That would be your least expensive route to go. Wheelspacers could be done, but most places don't make 4" wheel spacers, and even if they did, that is a lot of stress on the hubs.
    MNorby found the dually axles for me literally less than a week after he found the Wheels for me, so that was clearly the route to go in my situation.
    Good luck!
    Mike
  11. MrArmyAnt
    Dec 29, 2004
    662
    k then someone find me axels! or just a cheap d60...
  12. wforicv
    wforicv 1/2 ton status
    Feb 16, 2004
    165
    Back in Augusta, GA again
    Go over to AustinK5.net. I believe they have a detailed writeup on recentering. If I remember correctly, it is in the "Tech Articles" forum. You have to be registered to view. I would check to make sure but I forgot my password! Waiting for my email for my new one. Check it out.
    Eric
  13. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    i don't believe those exsist anymore:D
