mill a zero rate?
Discussion in 'The Garage' started by mouse, Feb 17, 2005.
  1. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    I thought I read somewhere that someone had milled their zero rate springs to get a better pinion angle. I have a bit too much angle on the u-joints, and I want to angle the rear end a little. When I brought the truck to the local driveshaft shop he recommended a 3 degree shim. I really don't want to use a shim and like the idea of angling the zero rate instead.
    Now, do I pay a machine shop to setup the milling maching to get a nice exact cut, or do I use a metal band saw and make as close of cut to perfect as I can and then file smooth?
    Any other options?
  2. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    There are good shims and bad shims. Good shims are made from steel. Bad shims are aluminum. A steel shim wouldn't bother me.
    Mill it if you go that route.
  3. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    I had a steel degree shim made - with countersunk bolt hole. Added 3/8"
    to the back which actually helped. The shim was welded to the ZR all the way around.
  4. sickquad
    sickquad 1/2 ton status
    Jul 23, 2003
    785
    Ma
    I milled my own "zero rate" with the angle I needed in it. I would have to say that doing it with a cutting blade would not work. Has to be done in a Bridgeport. It wouldn't be cheap to have a machine shop do it.
  5. jkce457
    jkce457 1/2 ton status
    Nov 22, 2002
    135
    Southbury, CT
    You can buy them already milled from ORD and then sell the ones that you have.
  6. mouse
    Nov 10, 2003
    1,448
    Great Falls Mt
    Thanks for the replies. I'll check with ORD.
  7. sickquad
    Jul 23, 2003
    785
    Ma
    If you get stuck for them. I could make you a pair. PM me.
