mini spool in a dana 44
Discussion in 'The Garage' started by chulisohombre, Jan 20, 2003.
  1. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,140
    14
    Bangor,Pa
    anybody used a mini spool in a dana 44.i found one at i think it was reider or randys r&p for 69 dollars.cheap locker but i want to know if anyone has used one and if anyone would be concerned about strength with them??thats the main thing im worried about.
  2. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Sounds like an okay idea... except that your steering will be affected anytime you have the hubs locked, 4wd or 2wd.
    Sounds cheap enough!
  3. 74beater
    74beater 1/2 ton status
    Sep 20, 2002
    242
    ELGIN ,TX
    its a spool..one solid piece..go 4 it..it works like a charm..but make sure your steering is solid..if not the spool will show you the weaknesses..
    all hail the almighty sawzall /forums/images/graemlins/k5.gif
  4. bigjbear
    Feb 18, 2000
    13,970
    450
    Marietta GA
    Not realy, he is talking about a mini-spool. Fits into the old carrier like a lock rite. If you use it make sure your steering parts are up to snuff.
  5. chulisohombre
    Apr 11, 2002
    4,140
    14
    Bangor,Pa
    yep its not a full spool.just takes the place of the spider gears and has the pinion shaft that holds it in place like it would the spider gears.i wouls only be using it off road and if the snow gets too deap on road.how much does steering get affected?or would a lockright be better or a powertrax noslip.although i think that does the same thing though as a spool would.for the price its worth a try.i wish someone would post that has used one before.that would help my decision much better.it should have the same characteristics as a full spool,so has anyone used one in the frontend and how does it run?
  6. FULLSIZE
    FULLSIZE Registered Member
    Aug 8, 2002
    76
    i do rock crawling and i could only tell the difference between a spool and locker when i was in rear wheel drive only. with the front in neutral, it would allow the locker to open up and ratchet. i ran a twin stick and as soon as i was back in 4wd it would turn shitty again. i would spool it. i welded my front 60. you just gotta make sure your P/S pump is fresh and you have a big enough cooler to not boil the fluid./forums/images/graemlins/thumb.gif
  7. chulisohombre
    Apr 11, 2002
    4,140
    14
    Bangor,Pa
    so you like the welded gears better than a locker?that in essence makes the carrier a spool.so you think it runs much better if its locked all the time?thats what i was figuring and since it goes inside the case i dont have to mess with resetting the gears.thats really the answer i was looking for.do you know how strong the minispool will be?ive actually never heard of anyone else asking about using one of these.thats why i was asking the forum.
  8. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    I installed one in my dana 44 about a year ago, First trip out I snaped the ears off both inner and outer axle shafts on both sides of the axle, I would not recommend a spool up front. Steering was also horrible, I had to unlock one hub to turn if I was not in mud. I would recomend some type of limited slip for the dana 44, I think it is a different story for the dana 60 which can probably handle it.
