mini spool question
Discussion in 'The Garage' started by tree_entz, Jan 24, 2005.
  1. tree_entz
    tree_entz 1/2 ton status
    May 4, 2004
    141
    N. Vermont
    got stuck w/ a 14b SF:crazy:
    blah blah blah,
    I was ignorant back then
    so, is there any reason why this wont work for either of the 14 bolts????
    http://www.polyperformance.com/shop/home.php?cat=48
    if I get a FF, then i'll regear, need to new brakes...
    (spiral..........)
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    you cant lock shafts together like that for regular street driving
  3. tree_entz
    May 4, 2004
    141
    N. Vermont
    perhaps i should have posted this in the 'regular street driving forum'?
  4. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    I think the carriers are different between the 14SF and the 14FF.
  5. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    carriers are way different. Nothing will swap between the 14 bolt SF and the FF. If you sink money into the SF that money is gone when you get a FF.
  6. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    Why CAN'T you? I drove around for a month or two with a welded rear axle on my K5. If you learn to drive like a sane person and not jump on it after each corner or don't expect to be carving corners like a mad man there is absolutely nothing wrong. In fact driving with a welded rear taught me to calm my driving down, something I severly needed after losing my license. If I had a welder here my Burb would probably have a welded rear right now.
  7. tree_entz
    May 4, 2004
    141
    N. Vermont
    way gone.......
    and for what it's worth...the guys at that place said
    'oh sure, no problem'......
    do you have any idea how much a drum cost for a SF!:mad:
