mini spool
Discussion in 'The Garage' started by milspecjimmy, Jan 24, 2003.
  1. milspecjimmy
    milspecjimmy 1/2 ton status
    Aug 28, 2002
    901
    raymond, maine
    any one make a mini spool for a 14BSF? if so who what when and where
    thanks
  2. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    i looked for 30 minutes and cant find one for bigger thaqn a 12 bolt. that was an auburn so they might have some i just couldnt find any. i kept ending up on racing pages
    nathan
  3. milspecjimmy
    Aug 28, 2002
    901
    raymond, maine
    yeah same here, i really cant afford a detroit, so i want to toss in a mini spool, one tire fire on the snow and ice SUX, and i have always driven in snow with a locker, lsd, or spool. depending on what i am driving at the time.
  4. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    The mini spool for a 14bff will cost about the same as a DL for a 14bff. If you aford a DL then just weld the spiders.
  5. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    Look for writeup on welding 14BFF here in garage.It tells how to do it and not ruin case so you can get detroit later. /forums/images/graemlins/thumb.gif
  6. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> He's looking for a minispool for a SF, not a FF. </font color>
  7. ZonkRat
    Jan 16, 2003
    1,003
    Axles prob won't hold up to spool or weld with SF.Aren't much stronger than 12B and think they're C-clips?? /forums/images/graemlins/thumb.gif
  8. milspecjimmy
    Aug 28, 2002
    901
    raymond, maine
    yes they are infact c-clip axels, and i know there not much stronger than a 12 bolt. when i become rich (or get a job), i am going to go out and buy a cucv p/u and take the axels off of that. i am looking for cheap and dont wheel it hard at all. a mini spool will work fine for my application. i just need to find one, and i really dont want to weld it.
  9. ZonkRat
    Jan 16, 2003
    1,003
    The writeup bout welding spiders should work on bout any diff.Found one that shows spiders welded together,not one i hunted.Was looking for this one if any one remembers it.Said weld 1 skip 1 weld 1 skip 2 weld 1 skip 1 weld 1 skip 2.Was refering to filling space in spider teeth.Was for 14 FF so tooth count could make diff in other size rears.Hope it helps. /forums/images/graemlins/crazy.gif /forums/images/graemlins/truck.gifer /forums/images/graemlins/thumb.gif
  10. milspecjimmy
    Aug 28, 2002
    901
    raymond, maine
    unless i can get another set of spider gears i dont want to weld the spaces, i want some thing in there that i can take out and replace very easily
  11. milspecjimmy
    Aug 28, 2002
    901
    raymond, maine
