misc burb questions doors/suspension
Discussion in '1936-Present Suburban' started by big_truxx, Apr 19, 2005.
  1. big_truxx
    big_truxx 1/2 ton status
    Oct 8, 2004
    2,272
    Canaan, Maine
    Just so I can ask my 2nd retarded question of the day :D burb and crew cab doors are one and the same correct?
    also what really is the difference between 3/4 ton and 1/2 ton? I have wanted a 1/2 ton for smoother ride and all for the family burb in my sig... but what's the real difference in them??
    thanks,
    chris
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Depending on the year. 70's burbs were the same except springs and axles. In 79 I think, GM changes the frame thickness, the axels and springs are the obvious, but the 1/2ton burbs from say 79 up used slightly thinner steel in the frame and maybe some crossmember variations.
    On the door issue, I'm not positive, but I think they are swappable, but I could be wrong, never tried.
  3. 6.2puller
    6.2puller 1/2 ton status
    Jul 8, 2004
    569
    New England
    AFAIK the doors are interchangable. I just purchased some rust free crew cab doors off ebay that should be here in NH by weeks end. They better fit :grin: I will post up if they don't.
    On the frames, I am not sure they are much thicker but I have both here and can check. I think with the rust it will be a poor comparison though.
    The cooling system on my 86 3/4 ton is way better than that on my 88 1/2 ton but that could be the TBI vs Carb more than the 1/2 and 3/4 ton differences. From my experience the 3/4 tons seeme to be more 3 speeds and less 700R4s.
    Once the E range tires came off and some Ds went on the 3/4 ton rides as smooth as the 1/2 ton. The big difference in mine are the 3 speed with 4.10s and the 4 speed with 3.73s. The 3/4 ton is much louder on the highway with the gearing it has than the halfton that is comfortable at 2500rpm while cruising.
  4. sweetk30
    Nov 1, 2004
    25,544
    539
    horseheads , ny 14845
    same doors my buddy does it all the time.
  5. mini_mull
    mini_mull 1/2 ton status
    Jan 22, 2005
    1,198
    Queen Creek, AZ
    Someone correct me if I'm wrong, but the 3/4tons never came with the 700R4s. Only the 1/2tons had overdrive until the '91 got the 4L80E. Therefore the 1/2tons should get better gas milage.
  6. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,862
    293
    Truckee, CA
    I always thought the 700r4 came in 3/4 ton's around 89-90 at least, before they switched to the 91 4l80. I couldn't drive when we had it, but im almost postitive our 90 3/4 ton with the 350 had an OD tranny.
    Could the 350 vs 454 vs 6.5 have a different tranny?
  7. tuffdogstudio
    tuffdogstudio 1/2 ton status
    Nov 1, 2004
    239
    New Mexico
    My 3/4 ton Diesel Sub came with a factory 700R4.
  8. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    my 90 2wd 3/4 had a 700
    unless your going to change the truck suspention go 3/4, they have a way better looking stance
  9. mini_mull
    Jan 22, 2005
    1,198
    Queen Creek, AZ
    I stand corrected. Thanks for the info. I wonder if the 700R4 ever came with gas 4x4 3/4tons. I don't know why not if it came in 3/4 ton 2wd and 3/4ton diesel 4x4s. Anybody have a gas 3/4 ton 4x4 w/ a 700R4?
    Ditto, 3/4 tons stand a lot higher and don't sag as much in the back.
  10. big_truxx
    Oct 8, 2004
    2,272
    Canaan, Maine
    I am just looking for a family type comfy ride burb ;) not looking to go wheeling or needing more clearance for tires or anything here. Just easy to get in w/ a set of running boards. Gotta love running boards :saweet:
  11. big_truxx
    Oct 8, 2004
    2,272
    Canaan, Maine
    84CUCV has a 3/4 4x4 gas job w/700 ;)
  12. 6.2puller
    Jul 8, 2004
    569
    New England
    I got my doors today and if they are different I certainly can't tell by looking at them. I gotta strip and paint them befor I install them but I am gonna say they are the same. They just don't have all the fancy power options in my case. Guess I get to swap everything over.
    From the sounds of things you are looking for a 1/2 ton for the easy entry and the smoother ride. Whatever you do don't remove the carpetting if you want a quite ride, even in the cargo area. It is like a base drum when not carpeted.
  13. big_truxx
    Oct 8, 2004
    2,272
    Canaan, Maine
    :waytogo: gotcha and know what ya mean. I need to tear out and replace sound deadening and carpet in my 82 DD :D w/ exhaust leaks :yikes: I'm used to driving trucks and being in military trucks (diesel w/ no insulation) and that's the prob. I know better :haha:
    I really would like a 1/2 ton but we will see what I end up w/. have about 6 ppl interested in the 75 so maybe sometime in the near future I could actually get me a burb to work on. Also I have got a new job as long as I pass 2 physicals on monday. Which I will undoubtedly. :waytogo: go burb for me!!! :woot:
    ALSO!!!!! on an 89 GMC SLE model would that indicate A/C and barn doors? :haha: I know nothing about the GMC models etc etc know most of the Chevy stuff. :thinking:
  14. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    yeah79 and up have thicker frames in them and other than that the rear springs have 2 more leaves in them and the axles are different.
  15. big_truxx
    Oct 8, 2004
    2,272
    Canaan, Maine
    Well I did know that one ;) :D :haha:
    thanks guys. :waytogo:
