misc burb questions doors/suspension
Discussion in 'The Garage' started by big_truxx, Apr 19, 2005.
  1. big_truxx
    big_truxx 1/2 ton status
    Oct 8, 2004
    2,272
    Canaan, Maine
    Just so I can ask my 2nd retarded question of the day burb and crew cab doors are one and the same correct?
    also what really is the difference between 3/4 ton and 1/2 ton? I have wanted a 1/2 ton for smoother ride and all for the family burb in my sig... but what's the real difference in them??
    thanks,
    chris
  2. OffRoad
    OffRoad 1/2 ton status
    Dec 8, 2002
    852
    New Brunswick, Canada
    frames are the same on 1/2 ton and 3/4 ton burbs. difference is springs, axles, trannys, etc.
    brand new 1/2 ton burb would prolly ride nicer. but now at near 20 years old? that'll depend on the burb, not the weight class.
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    My 3/4 ton rode pretty darn well for a solid axle truck. But the rear springs were pretty worn out. I wouldn't have used it as a real tow rig with those springs.
  4. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Are you talking 2wd or 4wd?
    On the 2wd, the 1/2-tons have rubber bushings on the A-arms... the 3/4-ton has greased metal bushings.
  5. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    Burb back doors are the same as crewcab back doors. The front doors of both are the same as single cab trucks and Blazers. All front doors are interchangable from 73 to 87 / 91.
    I always thought the frames got beefier as you went up. I know 3/4 ton truck frames are larger than 1/2 ton, and 1 tons are bigger than 3/4 tons. I thought that was the same for Burbs too.
    Eric M.
