  1. Christian Talley
    Christian Talley Registered Member
    Feb 26, 2000
    14
    About an hours drive southwest of Chicago, out in
    Misc. ?\'s
    starting to do a few improvements on an '84 Jimmy. Wondering if a bench seat from a new or newer chevy truck would go in without having to do any modifications, or just minor ones. Also, forgive my ignorance, but what's all this talk about "atf"? Whats the procedure? What is "atf".
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Re: Misc. ?\'s
    Not sure about the bench seat...........ATF(Automatic Transmission Fluid) , when sucked in thru your PCV valve, is supposed to burn the carbon off your valves........I tried it, and so have a few others, with mixed results.
  3. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    Re: Misc. ?\'s
    Ask Depdog, he installed a latemodel split bench in his K5.
    <font color=red>Mudzer</font color=red>
  4. Goose
    Goose 1/2 ton status
    1,127
    South Central Kansas
    Re: Misc. ?\'s
    Click on the "Search" button on the black bar in this forum. Specify the 4x4 K5 field and put "atf trick" under the search by phrase. There will be plenty of reading
