Misc. stuff, CUCV TM (-20, parts illustrations/numbers)
Discussion in 'General Parts for Sale' started by dyeager535, Oct 16, 2003.
  1. dyeager535
    26,975
    Everything here OBO within reason. Doesn't hurt to ask. Pretty interested in getting some of this stuff out of my garage. I prefer PM's, so this thread doesn't turn into 10 pages. I AM answering peoples questions, just not in the thread. Plus I can't forget to check PM's like I can the thread. :) Trying something here: email is dyeager535 at yahoo.com
    CUCV -20 TM, "repair parts and special tools lists". This is essentially identical to a GM dealers parts manual for the M1008-1031 series trucks. 400 pages or so, set up to be put in a 3 ring binder. May 1992, I'm guessing it's one of the newest ones there is.
    NOS Silverado 20 Fender Emblems, '81-up or so. Quantity 2. $10/each + shipping.
    Gray plastic piece for K5 passenger side forward fold seat. Goes on the back. Not cracked. Worn, but ok to use. Free+shipping.
    1981-1989 Guage clusters/parts. No tachs, but full size fuel gauges, speedometers, oil, temp and voltmeter, plastic housings, clear plastic lens, etc. $6 per gauge. Whole clusters $15. (not even sure I can make a full cluster with all of the pieces lol) May also have the shift indicator, needle, etc. Just PM me with your wants. Here are just a few of them...80PSI oil gauge, speedoemters, etc. (horn cap sold)
    Misc. wiring harnesses...
    1985 K5 wiring harness
    1989 Suburban underhood wiring harness, quad headlight. Engine wiring too, not cut.
    Following are all OEM stuff, variety of AC Delco or GM part numbers. Prices listed are GM or what I could find online, not what I'm asking. OBO of course on all:
    D1955
    22578692 '88-95 oil pressure sender switch
    1644131 Oil pressure switch, lesabre, etc. $40 +/-
    1984638 BRIDGE,GEN RECTIFIER 90-94 6.6L turbo cat vin J $14.13
    d1926a $98 ignition switch
    15013005 D1530F ELECTRICAL / SWITCH-DIMMER/MULTI-FUNCTION 2002 1995 C/K trucks $41
    15665282 D1802A SWITCH,ENG OIL PRESS '81-8581 C/K truck $12
    25036555 SENSOR,ENG OIL PRESS GA '88-78 A/G-body $17
    25519224
    10201489 350/454 oil pressure sender truck $50.
    14078902 15-8218 RELAY,FAN CONT '89 Vette, etc.
    2032085
    10467208 D1929A MODULE,ELEK IGN CONT '87-92 FWD, Fiero, etc $132
    15954529 D1547D SWITCH,I/P & INTR LP DIMR '95-85Astro, S10, etc. $12
    10205676 Oil pressure D1808 (may not be that part number, but it is a sub for it) sender/switch $32
    15043231 Day time running light module, $15
    10244496 OIl seal, SyTy, $2
    12551589 Oil filter adapter gasket $.57
    10172754 SyTy oil filter pipe adapter gasket
    10456288 213-324 knock sensor 2003-1985 262/350/454 etc $31
    Anything I haven't explained enough, or where year variation is important (such as fuse panel) please PM me and I'll do my best to figure it out for you. Can take pictures as well.
  2. ijakers
    ijakers Registered Member
    Apr 2, 2003
    34
    St. Martinville, Louisiana
    Re: Misc. stuff
    I want the manual if it goes can you check shipping to 70518
  3. white-rhyno
    white-rhyno 1/2 ton status
    Jan 27, 2002
    942
    Ellensburg Washington
    Re: Misc. stuff
    Hey,
    Pm'ed yoou.
  4. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Re: Misc. stuff
    Only one tank w/sending unit for carbed setup. All 31 gallon, all in good shape (some less surface rust than others, no dents or major exterior corrosion) none leak.
    how much?
  5. dyeager535
    26,975
    Re: Misc. stuff
    It's going, I'll try and figure out shipping this weekend and get back to you!
  6. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    Re: Misc. stuff
    Sent pm about the fuel pumps.
  7. 88jimmy4x4
    88jimmy4x4 1/2 ton status
    Oct 19, 2003
    947
    3
    Houston, Texas
    Re: Misc. stuff
    Do you have a steering column out of any of these?
    I need one.
  8. dyeager535
    26,975
    Re: Misc. stuff
    Sorry, no columns!
  9. 1984k5
    1984k5 Registered Member
    Dec 4, 2003
    20
    Re: Misc. stuff
    1983 V8 engine harness, complete (even has junction block and fusible links) uncut, great shape! $20
    I am interested in this item I live in S.C but the ride probably won't be a whole lot?
    I saw that you have a breather with the charcol filter remover? I just got one and it has a charcol filter in it is it better to get ride of it?
    Let me know /forums/images/graemlins/k5.gif /forums/images/graemlins/thumb.gif
  10. Silverado_K5
    Silverado_K5 1/2 ton status
    Jun 4, 2003
    707
    Weston, Oregon
    Re: Misc. stuff
    PM sent for Silverado 20 fender emblems. Let me know ASAP.
    Thanks,
    Doug
  11. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    Re: Misc. stuff
    PM sent on wiper items.
  12. Topdown
    Topdown 1/2 ton status
    Nov 26, 2002
    2,598
    Vancouver, Washington, U.S.A
    Re: Misc. stuff
    whats left? You have a few items I need but want to make sure they are still available.
    -Ryan
  13. dyeager535
    26,975
    Re: Misc. stuff
    Everything on that list I still have, short of the Silverado emblems that might be sold, but thats it so far.
    I've also got the stock frame carbed hard fuel lines which are in good shape (and EVAP) in case you needed those, I just didn't post them because they aren't worth shipping. Free to anyone that wants them, just can't see throwing away pre-bent hard lines in good shape, I hate having to flare/cut/bend all that stuff if I don't have to.
  14. Stoopalini
    Stoopalini 1/2 ton status
    Oct 17, 2000
    999
    Austin, Texas
    I'll take all the Q-Jet stuff + the steel fuel line.
    Send me an e-mail and we'll work out the details.
    Thomas.
  15. Stoopalini
    Oct 17, 2000
    999
    Austin, Texas
    I received your e-mail, but keep getting undeliverable messages when I try to reply?
    I'll PM you with my reply.
    Thomas.
  16. dyeager535
    26,975
    Back up to top. If you need some miscellaneous stuff, PM me, I might have it.
  17. thebigdaddyof2
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    Dorian,
    Might be interested in taking you up on your offer in the near future.
    I'm in the process of swapping axles (diff gear ratio) and bigger tires on a '90 Blazer for another member (Hustler). I know he'd appreciate having a working (as well as accurate) speedo. Should we talk in a PM?
    I also have interest in the BBC TBI parts.
  18. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    Interested in the tbi stuff, can you pm me with what all you have and how much you want for it.
  19. fordeater
    fordeater 1/2 ton status Premium Member
    Mar 21, 2004
    1,402
    Missoula, Montana
    pmd you
  20. big4x4ride
    big4x4ride 1/2 ton status
    Feb 11, 2004
    216
    Corpus Christi, TX
    price shipped to 78418
    700 to 241 adapter. I know very little about these, will it fit a 350/208 combo? I don't know. Have pictures if you want them. $25.
