Misc stuff
Discussion in 'Pacific Region' started by Muddytazz, Feb 2, 2005.
  1. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    81-91 chevy hood....$50
    very good 3-core gm rad....$50
    73-80 inner fenders...$10 each
    Misc door hinges, some good some need new bushings...$10 per doors worth
    D44 calipers....$25
    73-80 lower valance(piece below the grill)...$25
    Superwinch internal lockouts....$50
    10b spindles and hubs...make offer
    10b front open carrier....$35
    10b front 3.08 R&P....$35
    12 3.08 R&P....$35
    12b open carrier....$35
  2. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
  3. red77blazer
    red77blazer Registered Member
    Feb 13, 2005
    47
    Washington
    radiator
    what kinda shape is it in, and is it compatible with my blazer? how many core and is it rusy/leaking etc, i live in wa.
  4. jekbrown
    May 19, 2001
    45,030
    362
    Vancouver, WA, USA
    I might be able to use those D44 calipers.... trying to remember what years are supposed to work with my ff14b disc brake brackets....grrr...
    j
  5. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    These calipers are off a 77 D44.
  6. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    Jason, any 1/2 ton or 3/4 ton from 1973-87 (91) will work. Only difference is the size of the brake hose fitting. Dana 44's typically have std thread and 10 bolts typically have metric thread.
  7. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    And I just realized I have a set of D44 and 10bolt calipers, so take your pick :D
  8. jekbrown
    May 19, 2001
    45,030
    362
    Vancouver, WA, USA
    Thanks Kenny! :)
    as far as I know, the brake lines in the rear of my rig are standard... might have to double check that though. How do these calipers look? are we talkin "been sittin' in the backyard at the beach house for 20 years!" or...? :D
    j
  9. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    pm me your address again and I'll send ya some pics really quick.
  10. kennyw
    Jun 9, 2002
    13,223
    94
    Doesn't matter what you have on the rear for brake lines right now, your gonna need to add rubber hoses to the ends of the steel line to allow the movement of the caliper. You just need to know which style hose to buy based on what caliper you get.
  11. jekbrown
    May 19, 2001
    45,030
    362
    Vancouver, WA, USA
    well, it would matter if I didn't wanna have both standard and metric fittings on my rear brake lines... wouldnt it? I mean, i know you can get hoses with any kind of fittings on either end, but I want all standard or all metric... none of this mixed units crap. Thats stuff is annoying! :)
    j
  12. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Easiest way to tell this....your K5 was originally had 85 brake lines correct? If your still running those lines, then they are the metric fittings, but if you are running the 14FF lines or you completely replaced the lines all together, then you'll have to find that out.
  13. kennyw
    Jun 9, 2002
    13,223
    94
    The only part that is metric is the banjo bolt... rest is all NPT thread. The metric hoses go from the metric banjo bolt to a NPT thread already (like on your front brakes). It's not a big deal unless you already bought the hoses. Though you might want to try to match what you have on the front axle :grin:
