misfireing or something..what would you call this?
Discussion in 'The Garage' started by bryguy00b, Mar 2, 2003.
  1. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    when i turn my truck of ...sometimes it will just turn of..and other times it will like stumble and keep running for a second after i turn the key of and shake..im not sure what it is ive heard of it befor..what causes that?
  2. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    oh yea..and the idle is set a little high if that makes a difference..so its running at a little higher rpm when i shut it of..
  3. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    back your timing off a little bit.
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Its called dieseling. My truck gets it sometime back in AZ where I am from when it is hot. My motor will get pretty warm from the outside heat being 100*+ and the motor being hot from stop and go driving. You turn the key off, and it rumbles for a few seconds.
  5. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    well its in the teens here so it cant be getting hot..i dunno...sometime it does it and sometimes it will just shut of and thats that. im not ganna worry bout it really....its just a little anoying..
  6. Tshane
    Tshane 1/2 ton status
    Nov 26, 2002
    144
    Peoria, Illinois
    more than likely it is your timing /forums/images/graemlins/truck.gif
  7. schmuck
    schmuck 1/2 ton status
    Nov 11, 2002
    523
    nola(new orleans LA)
    turn the idle down your getting to much fuel at idle
