misfiring like a mofo!!!help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ilikeitloud, Feb 9, 2004.
  1. ilikeitloud
    ilikeitloud 1/2 ton status
    Oct 30, 2003
    134
    edina, minnesota 55424
    i recently did an oil change on my k5 a couple days ago. and now it sounds like its misfiring ALOT. when i give it gas off the light it makes an ass load of popping and sputterin sounds from the exhaust. it never did this until the oil change. what could be thecause
  2. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    Timing....
    I had a problem on another vehicle where it would only mis-fire when I was accellerating. Turned out to be bad plug wires that were arcing. Just a thought.
  3. ilikeitloud
    Oct 30, 2003
    134
    i was gonna do new cap,plugs,and rotor this week hopefully it should help
  4. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Oil change won't cause that prob but you may well have pulled a vacuum pipe off when in the motor bay or dislodged a plug wire or something. Have a good look around where you were working and look for something hanging off or trapped. /forums/images/graemlins/thumb.gif
  5. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    Or possibly burnt plug wire by bumping it into the manifold.......Double check everything you touched or rubbed up against.
    Bill
