missing at high rpms?
Discussion in 'The Garage' started by tecton, May 2, 2004.
  1. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    truck seems to want to miss/sputter/backfire around 4-5000rpm
  2. micah
    micah 1/2 ton status
    Sep 18, 2003
    374
    Austin, TX
    Could be fuel delivery problem. The stock manual fuel pump has a hard time keeping up at those rpm's. Or it could be time to rebuild the distributor.
  3. 1-ton
    Apr 17, 2004
    2,890
    169
    Las Vegas, Nevada
    I would vote for ignition since it is happening at higher RPM's, but I don't count fuel system out either.
  4. gm guy
    gm guy 1/2 ton status
    May 1, 2004
    151
    Vancouver Island but work in Ft Mcmurray Alberta C
    Check your timing at idle and overal @ 3500 rpm. Maybe the vacume advance on your dist is not funtioning. /forums/images/graemlins/k5.gif
  5. Can Can
    15,555
    152
    Cochrane, Alberta, Canada
    I'm willing to bet you have one or two dying wires. They always show up under load at higher RPMs...
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Are you running stock HEI with stock replacement parts? Stock HEI isn't too good at high RPM's. To get the best RPM range out of HEI you must upgrade the coil. /forums/images/graemlins/k5.gif
  7. gm guy
    May 1, 2004
    151
    Good tip. I'll get a better coil too!
  8. diesel4me
    Jul 24, 2003
    17,583
    945
    Massachussetts
    I hate to be a pessimist,but if its a chevy and it breaks up at high rpm and its not the plugs,wires,cap,rotor,or a fuel problem as already stated--its time to check for a round lobe on your camshaft--nearly every small block I've owned had(or still has! /forums/images/graemlins/whistling.gif)a bad lobe.Usually its an exhaust lobe that wears.This causes a backup of exhaust gas in that cylinder,and when the intake valve opens,the leftover exhaust tries to escape into the intake and out the carb,or throttle body--and it screws up the other cylinders by interfering with the flow of fuel/air mixture to the other cylinders.If you take off the air cleaner and rev it up high in neutral,you'll hear a gargling sound,and perhaps backfiring through the carb--that means its time for a new camshaft and lifters.Hope I'm not right in your case--Good Luck! /forums/images/graemlins/crazy.gif
  9. tecton
    Dec 1, 2002
    1,553
    WV
    the engine just turned 20,000miles since it was built two days ago
    cam would wear out that fast? /forums/images/graemlins/thinking.gif
    distributor was replaced some time ago....mabye end of last year
  10. gm4x
    gm4x 1/2 ton status
    Apr 6, 2004
    347
    Pendleton, Indiana
    What about valve job at time of rebuild? Valve springs (rate) checked (or springs replaced?) Possible valve "float" at higher RPM?
    20,000 miles on motor after a 2 day ago rebuild? /forums/images/graemlins/yikes.gif
  11. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    he is saying: two days ago it turned over 20,000 miles since the rebuild....i think
