missing problem
Discussion in '1992-Present Chevy & GMC models' started by gmaniat, Dec 12, 2002.
  1. gmaniat
    gmaniat Registered Member
    Dec 12, 2002
    5
    Lawrenceburg, KY
    I have a miss that will not go away. I have a 89 sub. brand new motor new plugs, wires, cap, and rotor button. Still have a miss. Also throws a code 42 which is the EST either grounded or opening. I have checked the wiring no obvious problems. Can someone help before I go on a rampage?
  2. MOABDADC22
    MOABDADC22 1/2 ton status
    Jul 24, 2001
    1,348
    Cheyenne, Wy
    Check the new plug wires with an ohm meter..See if the resistance is within manufacturers specs. I had a brand new set of wires that looked intact, but had a small problem with the inner core and caused a miss.
