Missing
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 83_K5, Oct 31, 2002.
  1. 83_K5
    83_K5 Registered Member
    Aug 9, 2002
    5
    Iowa
    Just curious if anyone has seen spark plugs glow? My Blazer started missing last night on the way home so I popped the hood to look for something arcing in the dark, but all I could see was the number 3,4 and 8 spark plugs pulsating to a blue/white color. I suppose it was when it was sparking, but I have never noticed this phenom before and was hopping someone here could explain to me why it is happening. Thanks guys /forums/images/graemlins/1zhelp.gif
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    You must have a bad connection at the top of the plug, did you pull out the cables and checked if the nut is loose?
    That glow is an arc jumping from a bad connection.
  3. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,088
    488
    Grand Rapids area
    Yeah, what iceman said.
    Anytime you can see an arc, something is wrong. The only place where electricity should have to jump through a gap is inside the combustion chamber. Check out the plugs and wires. The missing is either coming from the spark being weak from having to arc somewhere or from the arc being a bypass to the plug (shorting to the block through the air).
  4. SAVAGE1
    SAVAGE1 1/2 ton status
    May 22, 2000
    1,104
    BAY AREA, CA
    I started to get this same thing after I put in new plugs and wires. Did you figure out the problem?
