Mixed up my piston rings, Which ones go in wich grove
Discussion in 'The Garage' started by y5mgisi, Apr 3, 2006.
  1. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    Please refer to the ilistration below:o So when i ulled them out of the box i for got which ones went where. So does the A ring or the B ring go in the top grove of the piston? BTW this is on a 500 cad if that makes a difference
  2. oneofthefewbmx
    oneofthefewbmx 1/2 ton status
    Oct 6, 2004
    579
    Copperas Cove, TX
    i dont know that much about caddy engines but...if it is ANYTHING like a chevrolet then the top ring will have a dot on it, the bottom ring will be the only one that looks that way and it will have 1 THIN ring on the top and 1 on the bottom of it...also i believe the top ring will be tapered on one side...sooo
    1. Top ring = tapered w/ a dot on it
    2. Middle = thick ring w/ no taper
    *thin*
    3. ring w/ waves
    *thin*
    hope this helps
    (i cant see the picture cuz im not a member) (i will fix that w/ the next paycheck)
  3. y5mgisi
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    thanks for the reply. but both my top and midle rings have chmfers on the inside and nothing on the outside, its just that theyre chafered on the top of the one type and on the bottom of the other. The pic(for those that can see it) shoes the two different typs they gave me. and the chamefer is on the inside of the rings. Wierd i thought.
  4. 1-ton
    Apr 17, 2004
    2,884
    165
    Las Vegas, Nevada
    Didn't the rings come with instructions? Most piston ring sets come with instructions telling you which side is up, which ring goes in which groove, ring gap, and offset positioning of the gaps. If you go to the piston ring manufactures web site, they may have a PDF file you can download with the instructions.
  5. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    The ring with either a dot or top with the inside bevel facing upwards is the top ring always.
