Mixture
Discussion in 'The Garage' started by 82_k5, Jan 23, 2005.
  1. 82_k5
    82_k5 Registered Member
    Oct 3, 2003
    94
    I have a 350 motor with a carter afb competition series carberetor. It keeps backfiring through the carb. The mixture is settable. Is it too lean, too rich or what? I need to get this thing running. Any help is appreciated. TIA
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Have you checked your timing?
    Harley
  3. 82_k5
    Oct 3, 2003
    94
    i know it's the carb cause the mixture screws got screwed up when i was putting it on a diff car
  4. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
    your plugs can tell you if your running rich or lean....
  5. 82_k5
    Oct 3, 2003
    94
    it was fine before i took it off. When i put it back on the mixture screws got screwed up. Is there a way to reset them enough to start it and than be able to fine tune it after that?
  6. rustbucket racing
    rustbucket racing Registered Member
    Apr 7, 2004
    6
    Screw them all the way in. Then take them all the way out. Count the turns it takes to get them out. Then put them in the middle. This should give you a baseline to start with. This should allow you to adjust it for fine tuning. Good luck.
  7. dirtwarrior17
    dirtwarrior17 Banned
    May 14, 2004
    1,820
    Redding, CA
    When the carb blows up in your face it usually means your too far retarded. Get a timing light and check it.
  8. 4by4bygod
    4by4bygod 1/2 ton status
    Nov 13, 2003
    3,859
    With My Tinfoil Hat
    Put a vac gauge on the carb. ( not the vac advance port the distributor uses, the other one), when you turn out the screws, turn them both equally, until highest vac is reached.
    That's your best A/F mixture, according to the edelbrock tech guy I learned this from. It's never failed to produce a nice tune for me. Check the timing too.
    Tom
