Mk IV vs. Gen V BBC
Discussion in 'The Garage' started by Enginerd, Jan 8, 2007.
  1. Enginerd
    Enginerd Registered Member
    Nov 1, 2006
    15
    Cody, Wyoming
    I was fortunate to recently buy 2 complete but dissassembled 454 cores.
    One is a late 1980's Mark IV and one is 1991 Gen V block.
    Which is better to build? Parts availability is probably better for the Mk IV, but the Gen V has an improved oiling system and a one-piece rear main seal.
    I plan to use one of these to build a 496. Any opinions on which I will have better luck with?
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the gen V has redesigned waterjackets and i believe you can only use gen V heads on gen V blocks. it you put a Mark IV head on the block the jackets overlap and end up leaking coolant into the oil.
    i would use the mark IV block.
  3. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    Mark IV all the way. The gen V has compatibility issues. You can use gen V heads on a mark IV, but not the other way around. I dont even think the gen VI heads will work on the gen V
  4. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Gen V and VI are compatable but you can't swap GEN V or VI heads with a Gen IV in either direction because of the coolant passages.
    I would built the Gen V engine if it were me. Gen IV stuff is what will start getting harder to find over the years and there are plenty of aftermarket Gen V and VI stuff available now.
  5. tiger9297
    tiger9297 1/2 ton status
    Jul 23, 2004
    1,205
    Tupelo, Mississippi
    The Gen V will have better cooling than the Mark IV. However, some of the old Mark IV heads are pretty good and can be bought cheap. If you go with the Gen V and want to upgrade the heads, you will have to go with a fairly new aftermarket head which will cost more money. If money is not a problem and you can justify a good set of Dart or AFR heads I'd go with the Gen V.
  6. Enginerd
    Nov 1, 2006
    15
    Cody, Wyoming
    Thanks for the replys.:bow:
    It seems as though we are pretty evenly split on the opinions about which block to use.
    Any more opinions?
  7. mostwanted
    mostwanted 1/2 ton status
    Feb 5, 2006
    765
    Kansas City, MO
    not to hijack, but...................
    anyone else here of a problem with misaligned lifter journals on BBC's?
