mmmmmmm 60
Discussion in 'The Garage' started by stockk5, Jun 25, 2006.
  1. stockk5
    Apr 13, 2004
    2,037
    73
    Cromwell, CT
    Well yesterday i picked up my Dana 60, she isnt pretty, and pretty angry right now, but gonna be rebuilding it for a few months and then put it in the k5. So.. anyone have a driver side axle shaft and hub/rotor assembly for sale? And or advice on how to get those broken studs outta the axle housing?
  2. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    a big fraeking e-z out. how much you pay?
  3. stockk5
    Apr 13, 2004
    2,037
    73
    Cromwell, CT
    400, its set up with 4:56 gears already, thats my main reason for picking it up, matches my rear 60 gears.
  4. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    damn... you're right, she ain't too pretty! lol! I wouldn't mess with those broken studs if an EZ out and a can of liquid wrench wont get them.. just strip the axle down and take just the housing to a good machine shop who can deal with it. Eventually there will be new studs in there that will be holding your front suspension together, unless you have your own time-tested stud-removal skillz, I'd leave it to a pro for safetys sake.
    j
  5. 79k20350
    Nov 22, 2004
    7,757
    Ct
    when using an e-z out of that size, you drilling a big hole...make sure to get it centered/ staight and because the hole is so big, it will weaker the studs grip on the housing, it should work...Just make sure you get one big enough to handle the job...
  6. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    GM Parts Direct has complete rotor/hub assemblies for about $275 new. OEM Spicer axle shafts aren’t too bad cost wise, used 60 shafts are VERY hard to come by, and you need to make sure you get the non-necked down shafts.
    On the studs, if you have access, the best solution I’ve found is to weld a nut on top. The intense rapid heat rise will shatter the brittle rust bond. Then when it cools enough to not ignite the lubricant, spray with a good penetrant to finish the cooling and it will usually come right out.
  7. 79k20350
    Nov 22, 2004
    7,757
    Ct
    This would be the ideal way to do it but it doesnt look like hes got anything there to weld too...
  8. sweetk30
    Nov 1, 2004
    25,554
    547
    horseheads , ny 14845
    removal of broken bolts/studs.
    tools needed : 1 welder and nut of the same size as broken bolt/stud.
    set nut over the broken bolt/stud and fill in with the welder and let cool just a bit so the heat will sink in and then remove just like a bolt.
    some times you need to heat the area or go threw 2-3 nuts. works like a charm.
  9. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    How can you tell? I can't see enough in the picture to be sure what he's got to work with, but I've done just as sweet suggests even when it's broken slightly below flush.
    This is an old tried-and-true method. First time I saw this I was probably 12 years old and my Grandfather (career boilermaker) used it to get out a flush broken bolt. It wasn't very large and he did it with an old Lincoln tombstone welder, try welding inside a nut with a stick some time! :eek:
  10. sweetk30
    Nov 1, 2004
    25,554
    547
    x2:confused: need better pics
  11. stockk5
    Apr 13, 2004
    2,037
    73
    Cromwell, CT
    here is a picture of the studs.. im gonna try drilling a lil and pb blasting them for quite some time.. then maybe easy out cuz my welder is broken right now. We'll see though, i still gotta clean it all off and such.
  12. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    What studs?! Man, I'm glad I live in AZ...
    With all that rust, I bet you don't get it with an ez-out. But if the ez-out fails, you cans till weld a nut on and welding in the hole will help break it loose (just don't burn through!!! :eek:) when it cools and contracts. Me, I would clean it up nice with a knotted wire wheel followed by a flap disk, then find/borrow/fix a welder to do the nut trick. But good luck!
    FWIW, I think I would also look into electrolytic bath for that housing. Man that thing is grungy.
  13. FOR MUD
    FOR MUD 1/2 ton status Premium Member GMOTM Winner
    Apr 6, 2006
    2,812
    397
    Clayton Del
    How long has it been sitting??
  14. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    haha, east coast, are you kidding?:p:
    the undercarriage of my '69 GMC and my dad's '96 Ford look equally as rusty. I am pretty sure the rust onset is a couple of hours after these trucks roll off the assembly line. The dana 60 I got has more moss than rust on it, and yeah its a friggin mess inside and out.
  15. 79k20350
    Nov 22, 2004
    7,757
    Ct
    Mine looked all of that bad. looks great now, just need a wire wheel on my angle grinder and some time. it got EVERYTHING around it covered but it all comes off pretty easy.
