MO Outfitters Front cross member
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by smartpatrol, May 7, 2002.
  1. smartpatrol
    smartpatrol Registered Member
    Feb 6, 2002
    86
    Ault CO
    Just fyi i just bought my replacement crossmember from MO outfitters(figured i would swap it out while the motor was out). I have to say that they do impressive work! It fit on the frame perfectly! one problem though /forums/images/icons/frown.gif with my stock suspension on my 83 K5 the bottom of the cross member rests on my front pumpkin DOH! so i have to wait till i install my lift to use it. Of course i removed the old crossmember before i found this out /forums/images/icons/frown.gif. hopefully the frame holds up till i can get it installed. Despite the one problem i had I do highly recommend this product!
  2. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    I guess it's time for a lift. My crossmember is cracked so I am doing the same thing this summer. Good Luck./forums/images/icons/wink.gif
  3. Zepplin
    Zepplin 1/2 ton status
    Aug 29, 2000
    920
    Bay City, MI 48706
    Too bad about the contact but, now you HAVE to get a lift. I plan on getting one as well. I thought it would make sense since I plan on doing a cross-over and the body is off the frame so, I can get to it perfectly.
