Moab Clean Up
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazer72, Sep 23, 2001.
  1. blazer72
    blazer72 1/2 ton status
    Apr 13, 2000
    939
    KCMO
    Wel Layne and I gave the 72 a once over today to finaly see what damage I did in Moab.
    Poped the ends out of the rt front axel shaft u-jointcups, the clips staryed but the ends of the 2 off the cups came off!
    The upper u-joint on the steering shaft is partway stripped!
    3 of the 3/8 grade 8 bolts on the front trany crossmember sheared no point of impact.
    Add this to what I already new one rear 12 bolt 1350 yoke and u-joint, the lt ft lower shock bracket was riped off, the rt front lockout fuse ring. And the rear axel spring pads were rounding off. All and all not much a bit off welding it ready to back.
