Mobil 1 drip?
Discussion in 'The Garage' started by roadnotca, Dec 22, 2006.
  1. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Has anybody else experienced this? I've been using Mobil 1, and I have drips from the engine, trans, T-case and diffs. They're all basically new or resealed.
    Is it a case of Mobil 1 will get past any shaft seal?:confused:
  2. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    I've heard this but find it hard to believe. I'm just about to put 0w40 Mobil 1 in my Dodge so I'll let you know if I spring a leak.
    They've been selling the stuff for years so I can't believe these old wives tales of it being 'too slipery' for some engines.
  3. bdozeraz
    bdozeraz 1/2 ton status
    Nov 8, 2004
    212
    Phx, Az
    I have noticed more leakage from my vehicles using synthetic oil vs regular.
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    If there is any kind of slight leak point synthetics like Mobil 1 will find them where dyno oils may not or just not leak as fast. If the seals are good synthetics shouldn't leak either.
    Harley
  5. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    If you think about it, there hasn't been any major $ incentive to perform long term testing on seals designed ~50 years ago, exposed to synths. :doah:
  6. 4by4bygod
    4by4bygod 1/2 ton status
    Nov 13, 2003
    3,859
    With My Tinfoil Hat
    Guys..
    synthetics made of PAO ( poly alpha - olefin ) basestocks ( which would include mobil one, some amsoil, and Royal Purple ) shrink and harden seals.
    Here's what the lubrication experts have to say, not just me:
    http://www.machinerylubrication.com/article_detail.asp?articleid=752
    Weaknesses of the synthetic-based lubricants include: limited additive solubility, reversal of ester-based synthetic base oil to an acid, seal incompatibility with some seal materials, and a significantly higher cost per gallon compared to most mineral-based oils.
    And this from an ester manufacturer ( hatco ):
    http://www.hatcocorporation.com/pages/about_esters.html
    esters are nearly always used in combination with PAOs in full synthetic motor oils in order to balance the effect on seals, solubilize additives, reduce volatility, and improve energy efficiency through higher lubricity.
    As with any product, there are also drawbacks to esters. The most common concern when formulating with ester basestocks is compatibility with the elastomer materials used in the seals. All esters will tend to swell and soften most elastomer seals however, the degree to which they do so can be controlled through proper selection. When seal swell is desirable, such as in balancing the seal shrinkage and hardening characteristics of PAOs, more polar esters should be used such as those with lower molecular weight and/or higher number of ester linkages. When used as the exclusive basestock, the ester should be designed for compatibility with seals or the seals should be changed to those types which are more compatible with esters.
    So, there you have it... it's the oil, attacking your seals. as you might guess, esters aren't cheap, and there's no law saying how much the oil maker has to put in there for you.
    Also, additive solubility is important, because if you take off your oil pan, after using a PAO oil, that stuff you can scrape out of the pan at the bottom is the additive package that you thought was protecting your engine... combustion temps always win..
    Now, if you want an oil that doesn't attack your seals, and maintains its additive package....click on the links below..
    Tom
  7. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Tom, you've finally convinced me. I gotta say, maybe Quantum Blue has the answer, and all the rest are being carried by their "big name". But Mobil1 did save my tranny. After a hard days trails on a NAPA car torque convertor, the TH350 couldn't figure between 2nd & 3rd. When I drained that Mobil1, it was "dark" ruby and it smelled burnt.
    Meanwhile, thanks for posting their addy once again.
    :xmas:
