Mobile Home axles
Discussion in 'Tow & Trailer' started by kennyw, Jun 9, 2004.
  1. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    Anyone have an idea what a mobile home axle would be rated for? I know there are probably more than one size out there but there is probably some way to get a rough estimate. I bought a set of mobile home axles that came with tires and rims a while back so that I could use the tires/rims to move a house... Now I have a set of nearly new tires and a couple axles laying around and want to put them to good use.
  2. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Usually 5k.
    Check the rating on the tires. It will give you a good idea as to how much the axle was/is rated for orginally. Unless of course the tires are mixmatched all aorund with different weight ratings.
    John
  3. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    The ones I see are usually 6000lbs.
    They could have different ratings but most of what i see is 6000lbs.
    /forums/images/graemlins/thumb.gif
  4. ugly_blazer
    ugly_blazer 1/2 ton status
    Apr 12, 2004
    1,214
    Are you wanting to use them for the trailer discussed in your other post?
  5. kennyw
    Jun 9, 2002
    13,224
    94
    That was one thought but I doubt I could get the capacity needed with the 2 axles I have now. I will probably just build a trailer around the axles I have instead for now. Then buy bigger axles w/duals for the big trailer idea.
    Right now all I have is a bumper pull 20' trailer with 2 3500# axles under it and a poor frame design (converted from an RV). So I need something with a better design and larger capacity for now and will probably build a 20' low deck w/ 10K rated trailer.
