mod ?,--extra capacity oil pan & high volume pump
Discussion in 'The Garage' started by big d, Nov 2, 2002.
  1. big d
    big d 1/2 ton status
    Oct 24, 2001
    1,236
    illinois
    is it worth it for a daily driver ? /forums/images/graemlins/confused.gif /forums/images/graemlins/1zhelp.gif i know summit has them fairly inexpensively, and that the fact extra oil = better cooling (like same for tranny pan). just want some input from ck5 brothers. thanks. /forums/images/graemlins/k5.gif /forums/images/graemlins/thumb.gif
  2. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    Thats not a bad way of doing it, The extra capacity will help keep the oil cooler some what but a eng. oil cooler would be better. I run both on the tranny and just the OEM cooler on the eng. But I run duel oil filters that adds up to about 2qt extra.
    Eric
  3. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    Just remember that if you have a hi flow pump without a bigger cooler you can actually make a hi heat problem. Reason being you out flow your heat transfer device, in other words: your oil goes thru the cooler with out enough time to cool completely. Samething happens when folks go to hi-flow water pump without getting bigger radiator. Just a thought hope it helps you.
  4. big d
    Oct 24, 2001
    1,236
    illinois
    dude, you have the exact same setup i do ! dual oil filter and the works. i only got a 305, but i want to keep her as healthy as possible. maybe ill get a hi flow water pump in the future to, dont know. thanks for the info. /forums/images/graemlins/thumb.gif
  5. big d
    Oct 24, 2001
    1,236
    illinois
    thanks for the info. /forums/images/graemlins/grin.gif
  6. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    i run a extra capicity pan with a high vol. pump. I like the fact that the pan is baffled and the extra cap. is good IMO as well. /forums/images/graemlins/grin.gif
  7. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I say go for it...Oil is what cools the bearing surfaces in the engine and the more cool oil you can get there, the better...I am going to be using a melling HV oil pump and an 8-quart oil pan (if it will fit) along with a Perma-Cool headered oil cooler in the BBC I am building to swap into my K5...
    Oh, always remember to swap out the stock oil pump shaft for a beefier on with a pinned-steel collar when using a HV oil pump...the HV requires a bit more force to pump than a stocker...
    Chris
  8. big d
    Oct 24, 2001
    1,236
    illinois
    many,many thanks. /forums/images/graemlins/thumb.gif
  9. jeffro
    jeffro 1/2 ton status
    Jul 2, 2002
    406
    Scurry, TX
    Yeah, and be sure to get high volume valve covers to hold all the extra oil pumping to the top end.
  10. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    You DO NOT need a high volume oil pump! It will rob HP and heat up the oil. The stock oil pumps pump way more then the motor can ever use! All the excess ends up going out the pressure relief valve and right back into the pan! If you plan on spinning high rpm a high pressure pump (or even just the spring in a stock pump) will do all you need. The rule of thumb for a SBC is 10psi per 1000rpm (i.e. 60psi oil press. at 6000rpm).
    A new pan with some baffles in it is always a good idea if you use your truck for things the designers did not intend.
