mod neccessary to fit 2.5" ram horns on 73+ frame!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TX Mudder, Oct 15, 2002.
  1. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    mod neccessary to fit 2.5\" ram horns on 73+ frame!
    I thought it was a direct bolt on, but it's not.
    On the driver's side motor mount (clamshell OE type) the part of the mount that bolts to the side of the engine block is in the way and has to be clearanced.
    I used my oxy torch - if it weren't for that, I think the only way to do it would be to remove that motor mount and work on it on the bench.
    I had to cut good sized notch on the back (towards the tailgate) side, but left a good chunk of metal next to where the motor mount insert metal clip is (If you look at any replacement motor mount insert, you'll know what I'm talking about.
    Just thought I'd pass the word because the idea I got by asking around was that it is a bolt on.
    -- Mike
  2. dyeager535
    26,982
    191
    Re: mod neccessary to fit 2.5\" ram horns on 73+ frame!
    For that much effort, aren't headers easier? : )
  3. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    You don't understand Dorian, these ram horns look baaaaaaaad.
    When the exhaust is on, it should flow as well as shorty type headers but with manifold durability and quietness.
    And plus they look great.
    Cost about $86 plus shipping at gmpartsdirect (each.) Very comparable to BUDGET headers.
    Did I mention how cool they look?
    -- Mike
  4. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    lets see pics....
    grant
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I'm guessing that they dump straight down, right in the center of the head. I've got the factory 'vette mini-headers that dump in that location and also had to notch the bracket to make the drivers side fit. But since the engine wasn't all the way in the truck yet, we also fabbed a brace and welded it into the bracket to make sure that the bracket wouldn't bend. /forums/images/graemlins/cool.gif
  6. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    Got any pics of your install yet? I am looking at doing this myself soon. /forums/images/graemlins/thumb.gif
  7. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    http://home.houston.rr.com/chevy73/exhaust.html
    Rather than link pics, I've linked the exhaust page. It looks really good, especially since I routed the wires UNDER the mnaifolds like they are supposed to be.
    If you need any more info or pics, PM me.
    -- Mike
  8. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    One word of caution. I didn't learn that they won't fit the 2 bolt valve cover heads untill after I bought my manifolds. /forums/images/graemlins/rolleyes.gif The newer valve covers are wider and the arches will hit the cover before they seat fully. Clearancing will let them mount, but I decided it didn't look too good for gasket longevity...
  9. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    Mike are yours still holding up? Mine are doing good. Had one of the nuts at the collector back off and started leaking, tightened it down and kept on getting up.
  10. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    Mine are fine. I thought I had a leak, but it was just some oil or something burning off. Good so far.
  11. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    -- Mike
    [/ QUOTE ] They look better than a set of headers? headers give that modified motor look while manifolds are...well manifolds. /forums/images/graemlins/wink.gif Just my H.O.
