Model 205 lubricant specs
Discussion in 'The Garage' started by camiswelding, Sep 9, 2003.
  1. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    My books list ATF dexron 2 for 80-89 model 205 transfer cases.. but the earlier ones took 80/90w... does anyone know why this change and is there any advantage to the gear oil instead... they didnt change to some type of needle bearing in the later models that needs lighter lubricant ..did they?
    thanks
    cam
    (now the owner of a k3500 3 + 3 crew cab with 39k original miles.. add that one to the fleet!!! /forums/images/graemlins/crewcab.gif)
  2. doctor4x4
    doctor4x4 1/2 ton status
    Jan 22, 2002
    1,450
    Los Angeles
    sounds like a nice ride
    but i think ya miss read or they misprinted the spec i am sure it takes good ole gear oil call the dealer 2 dbl check tough
    R
  3. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    No internal differences I'm aware of. I think they changed it for economy's sake - thinner oil has less drag or something. I took ATF out of my '91 crewcab's 205 and filled it up with gear oil. Quieter and shifts nicer /forums/images/graemlins/thumb.gif
  4. bigblock44k5
    bigblock44k5 1/2 ton status
    Jun 8, 2003
    396
    Hurlburt Field, FL
    Gotta love a 6-pack truck.
    Anyway, I dont know if its a misprint or what, but with a gear driven transfer case, it is much better to use gear oil. Chain driven TC's use lighter weight oil so it will soak into the chain. You dont have to worry about that, you just want something that wont get thin when hot to protect those gears.
  5. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    U2Low is on the money here. I went threw this over a year ago, when I had troops pulling a service on a M1031 CUCV. They were changing the transfer fluid because of water contamination, I interviened with "hey don't put ATF in a 205 case only the 208 takes ATF!" The senior mech hands me the lube order which states ATF /forums/images/graemlins/blush.gif
    WTF? this can't be right, I've had trucks with 205s before I KNOW they had gear oil in them. Well thanks the the CK5 crew: New Process switched to ATF for mileage purposes in the early eighties. And AFAIK (or anyone else) they didn't change thing internally. /forums/images/graemlins/wink.gif
  6. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Yep they went to ATF, had me all goofed up the first time I drained one and atf came out.
    They definately shift better when they are filled with 90 wt.
    What kind of steel are they using that soaks up oil ?
    I was of the understanding that they used lighter lube in the chain drives because the pumps would not move the thicker lube and the case would fry bearings.
  7. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    So, about a 241 case - which calls for ATF when you run 30w in a 203....Kind of the same thing???? ATF just doesn't seem right....Any thoughts??????
  8. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Take a look at the gears in a 208, 231 or 241. They're planetary gears, just like in an auto tranny. ATF works just fine in 'em. /forums/images/graemlins/cool.gif I've got a 231 with 144K miles on it and a 241 with 159K miles on it. Never had a problem with either one. /forums/images/graemlins/thumb.gif
  9. bigblock44k5
    Jun 8, 2003
    396
    Hurlburt Field, FL
    I didnt mean the metal soaks up the fluid, I meant the oil will getinside the roolers and sliders of the chain better with lighter weight oil.
  10. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    I've seen a bearing life/load chart and after than I wouldn't run ATF in anything like a 205. They spec different oils for good reason usually (pumping) but in this case it seems to be pure economy. The best thing to put in there is 80-90, unless you have some real special circumstances like extreme cold weather.
    For those of us with auto's, it's nice to know that ATF will work since sometimes the tranny oil gets through the seals but it's not ideal.
