Model 80 fuel filter leaking.....
Discussion in '1982-Present GM Diesel' started by 84CUCV, Apr 22, 2004.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    Is there a way to fix it? Or replace with something else? If so what are you guys using?
    thanks mike
  2. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    Where it be leaking from? Did you get the knobs tight? Did you make sure there wasn't 2 gaskets on one of the posts? Are both the hold down clips on and tight? Claps on the mount tight? Just some simple things to check first!
  3. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    Hey, its all good. Leaking from the bottom. I am goin to get a spin on, just dont know what kind. PIA thanks
  4. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    Can someone please give me some good websits for filter diesel fuel, now the leak is real bad and this is my only ride for a while.
    thanks /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif
  5. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    Where is it leaking exactly? Have you tried taking the filter off and making sure its all correct? Did you close the valves tightly after you bled the lines?
  6. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    I didn't take it off, but it is comeing from the bottom of the filter and everything is tight. Heck the things just about new. thanks
