Modifying after lift
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chevy4x4, May 5, 2000.
  1. chevy4x4
    chevy4x4 1/2 ton status
    Apr 27, 2000
    1,454
    With 4 inches of lift, are there any things i have to lower, lenghten , modify etc..........?
    Would driveshaft angles be Ok?
    Steering?
    I know i would have to lenghten the brake lines.
    Thx
    Chevy 4x4
  2. Corey-88K5
    Corey-88K5 1/2 ton status
    720
    Home: Michigan, Stationed: Hill AFB (Home of Moab.
    With a 4" lift, you can actually get away with stock brake lines, driveshafts, & steering system. You will need to correct the draglink (twist to adjust the wheel back center).
    You SHOULD: add a dropped draglink or raised steering arm, and get longer brake lines. The rest should be ok. Some people do experience vibrations at 35mph, you can drop the t-case (which I would NEVER suggest, why lift it to lower components?) or use rear shims. If you use blocks, (once again, I don't suggest only because blocks should be used to support houses not trucks) they are usually tapered to the correct angle, a shackle flip can cause problems. I had them, others had not.
    Best of luck,
    Corey
    88K5
    [​IMG]<font color=red>Girls Like Guys In Bow Ties
    http://www.geocities.com/corey_perez
  3. mudfanatic
    mudfanatic 1/2 ton status
    Feb 18, 2000
    614
    Aloha, Oregon
    with my 2.5 inch lift I was using my brake lines as limiting straps for the front axle (with the swaybar connected), this is somthing you would want to avoid.
    '77 K5
    <font color=red>mudfanatic</font color=red>[​IMG]
  4. 88Jimmy
    88Jimmy 1/2 ton status
    100
    Las vegas, NV
    Corey
    I have to ask why you would not drop the Tcase ?????
    Maybe you don't understand why it should be dropped
    maybe you don't understand about the angles of the drive line.
    350 Vortec TPI D60 14Bolt 4.56 4"lift 35 BFG A/T
