mods to make top easier to remove ?
Discussion in 'The Garage' started by big d, May 19, 2005.
  1. big d
    big d 1/2 ton status
    Oct 24, 2001
    1,236
    illinois
    i wanna make the top easier to take off instead of being made to remove a million- and- a-half bolts ? :mad: :p: :frown1: :confused: it be nice to have ones with a rubeer head like jeeps have that u can remove by hand instead of tools. ;) :D :cool1: :grin: id like to retain my rear panels also. so it must function and look good at the same time. thanks for any ideas or comments ahead of time.
  2. blazerpro79
    blazerpro79 1/2 ton status
    Jan 4, 2005
    528
    Simi Valley, CA
    air ratchet.... takes under a minute to get all the bolts out...
    thats only if you have air access...
    i understand what you mean though, it gets too hot sitting in the back unscrewing them.
  3. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    take the top off and leave it off? works for me. :grin:
    j
  4. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Battery powered drill.....................cheap at a flea market..........just throw it in the back!
  5. MOBK5
    MOBK5 1/2 ton status
    Apr 5, 2005
    180
    MCAS Cherry Point, NC
    I just run four of the bolts and it holds fine.
  6. Boondocks
    Boondocks 1/2 ton status
    May 10, 2005
    129
    Massachusetts
    I had this idea years ago, but never researched the parts list.
    There is an aircraft fastner that looks like a metal button on a short stud. It fits through a female receiver that has a hole with a slot that gets thicker as you get further from the hole. The slot goes toward the front of the vehicle.
    Mount the buttons on the top and the receivers on the bed rail. You set the top on with the buttons in the receivers and push it forward, which draws the top down snug on the seals. Then just put the forward bolts in to keep everything in place.
    A follow-on idea was to make bed rail caps to put on when the top was off.
  7. blazd88
    blazd88 1/2 ton status
    Mar 16, 2004
    1,055
    Lubbock, Tx
    run less bolts or none at all my top only goes on when weathers bad(rain or snow) iv actually driven around with no bolts in it(not a great idea) but it was fine and never leaked.
    just take it off and leave it!!!!!
