modulator adjustment?
Discussion in 'The Garage' started by bigbadchev84, Mar 27, 2006.
  1. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    how do i adjust the vacuum modulator on a th400?
  2. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Assuming you have an adjustable modulator you use a small screw driver and turn the screw that is inside the vacuum fitting. Make small adjustments at a time.
  3. bigbadchev84
    May 17, 2004
    2,191
    Hermiston, Oregon
    ok well i got that part but what i meant was what happens to the shifting when i turn th screw in? out? thanks
  4. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Can't remember which is which but one way will make the shift later firmer and the other will make it earlier and softer.
  5. diesel4me
    Jul 24, 2003
    17,540
    930
    Massachussetts
    in ----out....
    Turning the adjusting screw IN makes it shift a bit harder and later..turning it OUT makes it shift softer and earlier...you'll only get a range of about 10-15 mph difference at what speed it shifts at,and only a firm shift if you crank it IN ,there isn't a huge difference really..
    I read your other post...sorry its the direct clutch,I was hoping it was something easy and cheap for you to fix..:(
