Moisture in Air Filter housing
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 90K5, Aug 18, 2000.
  1. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Yesterday when I was messing with my air filter I noticed that there was moisture in there just sitting in the bottom of the housing. Its not gas or oil and I don't know where I came from. I looked in there today and its still there. I have a K&N that I just cleaned a week or so ago. Could it be oil from it? That wouldn't really explain why its on the outside of the airfilter though. it also looks like something has soaked in to the plastic intake tube. Does anyone know what this could be? Thanks
    90K5
  2. White Knight
    White Knight 1/2 ton status
    889
    Ft Worth,Texas
    Check for moisture coming from your PVC line, dry the air cleaner and filter area disconnect PVC line and drive for a short distance..check for moisture if none, hook it back up and drive a short distance check again, if moisture is present..get the engine checked immediately!!!!
    White Knight
