Mold in bathroom
Discussion in 'The Lounge' started by 84gmcjimmy, Dec 12, 2005.
  1. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    In our main bathroom we have a jacuzzi tub (sp?)
    The sides against the wall liner thing are 'dead" level, the water just sits on the sides and doesn't drip off. We hadn't noticed this until a few months of showering. Now in a few spots we have little strips of dark brown-ish black mold around the faucet and along the tub where the silicon is.
    What can I do to prevent the mold, besides from wiping all water after showers. Also, how can I get rid of it?
    Thanks In Advance............
  2. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    About all You can do Steve is wipe it dry after You take a shower and use a good shower cleaner now and then that kills mold.
  3. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    Get a dehumidifier for the bathroom. I had to put one in mine cause the ceiling is getting mold on it. To get rid of the mold, try a toothbrush and bleach. Don't get the bleach on woodwork or cloth though.
  4. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    Tilex maybe?
  5. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Is that a cleaner?
    I'll try the toothbrush and bleach idea this weekend. And will just keep wiping it off.
    Not sure on the dehumidifier-how much noise do they make?
  6. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    My wife had some stuff that you spray on after you shower. About every other day and it kept the mold away. Here the humidity is in the 80-90% range much of the year so mold is a PITA. The stuff (can't remember the name) was with the bathroom cleaners at the store.
  7. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    sand blast it.
  8. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    Yeah. Our bathroom gets some sort of mold on the walls. I just spray it with tilex and run. Come back in a couple of hours and its gone. Stays away for a couple months.
  9. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    One of the guys I know is in Apartments . They clean get readies with Easy Off oven cleaner . Spray it in the shower/tub , let sit a little bit , and clean off .
    Wifey tried it in our shower in the old place , and it worked .
    I would try a little spot first to make sure it doesn't eat your surfaces though , just in case .
  10. kgblazerfive
    kgblazerfive keymaster Premium Member GMOTM Winner
    Dec 2, 2004
    10,607
    601
    Hooper, Utah 84315
    Its really mildew, I have a shower stall that it gets into the grout in the tile and the cheapest way I have found to get rid of it is to spray it with a bleach water mix works great and smells ok also. Most stuff that you buy has bleach in it anyway so I just cut out the middle man.
  11. shewheeler
    shewheeler 1/2 ton status
    May 4, 2001
    3,384
    Hollister, CA
    4 words:
    ven til a tion!
    install a fan that sucks out the steam or open a window
    Once you get the mildew cleaned up, wipe 'er down and keep 'er dry :o
  12. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    We have a fan in there, but after I have a shower, my mom or sister go into the bathroom to get ready and usually turn off the fanbecause it's a bit louder than quiet. :doah: I'd imagine that will help more if they left it on though. Thanks
    I will try this bleach spray we have.
    Mildew not mold? Makes sense, thanks!
    Thanks everyone.
  13. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Killed most of it. We have this "fantasic" bathroom spray with bleach. So I used that and let it soak for 10 minutes or so. Just a few faint stains, otherwise its gone.
    Thanks for the help!:bow:
  14. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    if the calking is turning brown/black it may be latex with is water based and will rot when wet, some one did ours in it.
    if it is you need to cut it all out dont just calk over it, and clean it with alcohol befor calking it with 100% silicon
  15. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Why would you want to kill it? Dont you know that stuff is edible. Or at least mildly hallucinogenic
  16. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    i lick the mold untill it stops growing
  17. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Dale, you odd.
  18. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    And Stave your a real fungi...Ahhh nevermind....:)
  19. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    they say if you pee in the shower it kills fungi.... :dunno:
  20. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    I heard if you pee in the shower the mold will attack your boys...serious!!
