Momentary lack in memory. Refresh on 10B/D44 spindle interchangeability...
Discussion in 'The Garage' started by BigOrange90Jimmy, Jul 24, 2005.
  1. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    I have a 73 3/4 ton D44 external hub front axle under my current project truck. The PO messed up the spindle on it's last bearing service. I was wondering if a spindle from an 87 10 bolt would work in its place?
    Sorry fellas for my memory lapse. Just let me know what will work.
  2. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    it depends on the bearing size. with that early of a model axle its possible that its the small bearing.
    i know for the big bearing spindles the inside diameter of the inner bearing is right around 2"
    the small bearing is significantly smaller
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    IIRC, the external hub dictated that it had a big bearing so the spindles are the same.
    also IIRC, the 3/4 ton got the big bearing no matter what.
  4. BigOrange90Jimmy
    May 24, 2002
    2,923
    Wilmington, NC
    thanks fellas. maybe someone will post up with a definite response. I was trying to save myself a heat stroke by not having to tear into the 10b if I didn't have to.
  5. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    The 10 bolt will have the larger inside bearing. If your D44 has the larger bearing spindle then yes, your 10 bolt spindles will work. All of the small bearing axles I ever had had a flat top passenger knuckle, but they were only 1/2 ton units.
    When I need a parts swapability reference I often go to www.autozone.com and look up the same part for both models and see if the part numbers match, in this case the inner bearing.
  6. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
