More 14BFF ?'s
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Hossbaby50, Feb 12, 2002.
  1. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    More 14BFF ?\'s
    Ok, I was told that you can get thick gears for the 14bff to fit in a 3.73 carrier. Is this right? Also with the thick gears, does it affect the install of a detroit at all?
    Harley
    My Chevy isn't broken, its just out of gas.<P ID="edit"><FONT class="small">Edited by Hossbaby50 on 02/12/02 08:37 PM.</FONT></P>
  2. SlyDog
    SlyDog 1/2 ton status
    Oct 23, 2000
    3,035
    Scottsdale, Arizona
    Re: Quick question on 14bff
    4.10 and lower I believe.
    <font color=green>[​IMG]1977 K5 GETTIN IT AWN[​IMG]</font color=green>
    BUILT <font color=red>NOT</font color=red> BOUGHT
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    They make thick gears for everything now so it shouldn't even matter.
    The break is 4.10 and numerically lower, and 4.56-5.13 in the other carrier.
    Thick gears are available to put 4.56s, 4.88s, or 5.13s where 3.42s used to be if that's what you want.
    Tim
  4. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    So if I have a 14bff with 3.73's then I only have to by thick gears to put in 4.56's? I don't need the 4.56 carrier, just the thick gears? Also is there any problems putting a dertoit in with the thick gears?
    Harley
  5. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    ttt
  6. nvrenuf
    Jan 7, 2002
    13,088
    252
    Mobile, Al.
    Re: More 14BFF ?\'s
    Yes, they make thick gears to fit your 3.73 carrier and no it will not effect the Detroit Locker. I have a 14FF, I used to have GM 4.56's with a Detroit in it and now it has aftermarket thick 5.13's (on a 4.10 carrier) with the same Detroit.
    My Detroit was about 10 years old when I did the gear swap. While I had it out I turned it around so the less worn side of the axle gears would now become the primary side facing the axle - something to think about if yours is older.
    80 K10 w/ 468 and 1 ton stuff
    You don't scare me, I got chunks of guy's like you in my stool!
    www.nvrenuf.fws1.com
  7. thatK30guy
    Jan 12, 2001
    32,076
    55
    No problems with installing a DL into the 3.73 carrier with thicker gears, BUT, make sure the carrier is the 4-pin carrier and not the 3-pin Gov-Lock carrier. If you have the 3-pin, you will need to purchase the 4-pin carrier to make the DL work.
    <font color=red>Only real men drive K30's!!!</font color=red> [​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>The K30 Collection</a>
