More 14FF Disc Questions
Discussion in 'The Garage' started by trukman1, Mar 14, 2002.
  1. trukman1
    trukman1 1/2 ton status
    Mar 5, 2002
    129
    Ohio
    Does anyone know if Corp. 10-bolt rotors and calipers will work instead of Dana 44 pieces? Would prefer to use pieces already in garage but not at expense of creating more problems with seals, bearings, etc. Thanks in advance for your help., Gary
  2. ChadH82
    ChadH82 1/2 ton status
    May 9, 2001
    400
    Stillwater, Oklahoma
    They should be the same if they are both 3/4 ton.
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Same stuff. Only difference is the banjo bolt size on the calipers...so just use the same clex line that goes with the calipers you use.
  4. greg83k5
    greg83k5 1/2 ton status
    Nov 2, 2001
    230
    space sity houston, texas
    i bolted my 1/2 ton calipers up no problem. should i be looking for the front lines for a 1/2 ton, rather than a 3/4 ton then? what the heck is clex??
    thanks,
    greg
  5. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Sorry that was ment to be "flex line". You just want to buy 1/2 ton front flex lines (even though 3/4 should be the same 1/2 might be cheeper).
