More 14ff Measurements needed
Discussion in 'The Garage' started by BowtieBlazer, Oct 16, 2003.
  1. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    Add this one to the archive...after reading this post: [ QUOTE ]
    Greg's specs
    Here are the specifics I need....
    (1)from the driver's side backing plate mount to the near side of the spring mount
    (2)from the passengers side backing plate to the nearest side of the spring mount
    before reading his post and after getting frustrated enough with my old mounts being welded and rewelded I bought new spring mounts and starting on a clean slate with an angle finder /forums/images/graemlins/shocked.gif /forums/images/graemlins/mad.gif I still messed it up by welding the spring mounts the right distance apart, but my axle now is off centered which equals dogwalking and bad driveline angle (side to side) /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif
    /forums/images/graemlins/thinking.gif
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    Hmm... This is pretty easy for you to figure out youself with a tape meausre and 3rd grade math. Measure distance from backing plate to backing plate. Measure distance between outside edges of spring pads. Subtract distance between spring pads from distance between backing plates. Divide the product in half. That number should be the distance that each spring pad should be from the backing plate, so long as the spring pads are the proper distance apart right now.
  3. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Yep, that is exactly how I set mine up. I needed 40" center to center distance or 42.5" outside to outside with a 2.5" wide perch. Measure the distance from backing plate flange to flange, subtract 42.5" and divide by two.
    That is pretty much the only way to do it in your garage, it is vitually impossible to find the center of a 14BFF and measure out from that.
    My math must have been correct, it bolted up right on the money!! /forums/images/graemlins/thumb.gif
