More 203 Questions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BeyondReason, Jul 6, 2001.
  1. BeyondReason
    BeyondReason Registered Member
    Jul 5, 2001
    20
    Arkansas
    How can I tell if my 203 has had a part time kit put in it. I bought the case used and will be rebuilding it soon. What do you look for in the part time components. I'll get away from it if I know what to look for.
    79" Jimmy, 8"lift, 3"body,38.5s, RockRam, lots more stuff
    BeyondReason
  2. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    The case will have two wheel low range,
    and two wheel high range.
    Hold the front output yoke, shift through the different ranges, while spinning the rear output yoke.
    Goo d luck
