More 3/4T-1T axle q's
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fr8train, Oct 29, 2000.
  1. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    More 3/4T-1T axle q\'s
    What brand, year, model truck/van would most likely have 4.10-4.56 geared axles that work under the K5? Went looking around archives and just lost attention span. Is it wise to stay away from 2wd rears?
  2. Cavalry
    Cavalry 1/2 ton status
    Oct 1, 2000
    978
    upstate NY(although I cant figure out why)
    Re: More 3/4T-1T axle q\'s
    My 85 K3500 had a D60 in the front and 14bolt in the rear with 4.10 factory. There is no difference i know of in HD 14 bolts from 2wd to 4wd as long as your ratios are the same you are all good. Remember to stay away from dually axles unless you are looking for that look in a K5 Luke
  3. fr8train
    Aug 2, 2000
    1,712
    Maryland
    Thanks man, I am kinda not understanding the dually part. Is the dually axle spaced differently? I am really struggling with this swap thing here.
  4. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I'm pretty sure 2WD and 4WD came with 4.10s my friend with an '86 C20 has 4.10s with a 14SF and they are factory. The yare lower from the factory for towing I guess.
    90K5
  5. fr8train
    Aug 2, 2000
    1,712
    Maryland
    Thanks for the input, do you know if the C series were ever equiped with FF or did they all just come with SF?
  6. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    Most of the older 3/4 ton 2 WD trucks came with the FF 14 bolt.
    Rene
  7. fr8train
    Aug 2, 2000
    1,712
    Maryland
    Sweet, I was really getting confused with this stuff. I having been scavenging a few places here and cant figure out what is going to be worth my time and $$$$.
  8. californiak5
    californiak5 1/2 ton status
    Oct 25, 2000
    820
    Oceanside, Ca. 92056
    You want to try and find a 3/4 ton ff14 rear end if this is going on your 88 Jimmy, that way it is a direct bolt in and you won't have to have the spring perches moved. And by the way, I know that 1976 K20's came stock with 4.10's.
    [​IMG] I have to agree with the Puddy Cat. [​IMG]
  9. fr8train
    Aug 2, 2000
    1,712
    Maryland
    I cant say thanks enough for everyones help on this post.
  10. Shawn
    Shawn 1/2 ton status Premium Member Author
    1,753
    5
    5280'
    I'm pretty sure the perches will have to be moved and the shock mounts hang down farther which is great for running long shocks but bad if you like rocks.
    Shawn
    87 K5
    http://www.off-road.com/chevy
  11. Big B
    Big B 1/2 ton status
    222
    fort worth texas
    I just put a 14ff out of a burb in to my 80 k5 and it all lined up perfict did not have to jack with the perches .
    bigb4x4.coloradok5.com
